My dad helped set up this router, so I'm don't know much about what the problem is exactly
All I know is that every 5-10 minutes, thbe router would shutdown and restart, with the same "Caught signal 15" in the logs
Mon Feb 10 00:16:08 2025 kern.warn kernel: [ 49.951415] 7981@C01L2,RTMP_COM_IoctlHandle() 1517: -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_INIT
Mon Feb 10 00:16:08 2025 kern.warn kernel: [ 49.959534] 7981@C01L2,RTMP_COM_IoctlHandle() 1494: -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_UP
Mon Feb 10 00:16:08 2025 kern.notice kernel: [ 49.967559] WiFi@C01L3,wifi_sys_open() 856: wdev idx = 4
Mon Feb 10 00:16:08 2025 kern.notice kernel: [ 49.973163] 7981@C18L3,BuildChannelList() 507:
Mon Feb 10 00:16:08 2025 kern.debug kernel: [ 49.977744] wdev_attr_update(): wdevId4 = 92:83:c4:64:1e:f1
Mon Feb 10 00:16:08 2025 kern.info kernel: [ 49.983346] apcli0: update addr to: 92:83:c4:64:1e:f1
Mon Feb 10 00:16:08 2025 kern.notice kernel: [ 49.988434] 7981@C08L3,hw_ctrl_flow_v2_open() 13: wdev_idx=4
Mon Feb 10 00:16:08 2025 kern.info kernel: [ 49.994308] mtk_ppe_dev_register_hook : ineterface apcli0 register (2)
Mon Feb 10 00:16:08 2025 kern.warn kernel: [ 50.003672] 7981@C01L2,RTMP_COM_IoctlHandle() 1517: -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_INIT
Mon Feb 10 00:16:08 2025 kern.warn kernel: [ 50.011829] 7981@C01L2,RTMP_COM_IoctlHandle() 1494: -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_UP
Mon Feb 10 00:16:08 2025 kern.notice kernel: [ 50.019874] WiFi@C01L3,wifi_sys_open() 856: wdev idx = 5
Mon Feb 10 00:16:08 2025 kern.notice kernel: [ 50.025525] 7981@C18L3,BuildChannelList() 507:
Mon Feb 10 00:16:08 2025 kern.notice kernel: [ 50.030117] 7981@C23L3,RadarStateCheck() 291: e[1;33m RD_SILENCE_MODE e[m
Mon Feb 10 00:16:08 2025 kern.notice kernel: [ 50.037104] 7981@C23L3,DfsCacNormalStart() 3980: [RDM] CAC 65 seconds start . Disable MAC TX
Mon Feb 10 00:16:08 2025 kern.debug kernel: [ 50.047416] wdev_attr_update(): wdevId5 = 9e:83:c4:64:1e:f1
Mon Feb 10 00:16:08 2025 kern.info kernel: [ 50.053019] apclix0: update addr to: 9e:83:c4:64:1e:f1
Mon Feb 10 00:16:08 2025 kern.notice kernel: [ 50.058377] 7981@C08L3,hw_ctrl_flow_v2_open() 13: wdev_idx=5
Mon Feb 10 00:16:08 2025 kern.info kernel: [ 50.065458] mtk_ppe_dev_register_hook : ineterface apclix0 register (4)
Mon Feb 10 00:16:08 2025 daemon.info gl-repeater[2356]: (gl-repeater.lua:192) load wifi config...
Mon Feb 10 00:16:08 2025 daemon.info gl-repeater[2356]: (gl-repeater.lua:214) found radio mt798111
Mon Feb 10 00:16:08 2025 daemon.info gl-repeater[2356]: (gl-repeater.lua:214) found radio mt798112
Mon Feb 10 00:16:08 2025 daemon.info gl-repeater[2356]: (repeater.lua:1082) ntp been valid
Mon Feb 10 00:16:09 2025 daemon.info gl-repeater[2356]: (repeater.lua:1333) no saved network
Mon Feb 10 00:16:12 2025 daemon.err usbmuxd[8786]: [00:16:12.011][3] usbmuxd v1.1.1 starting up
Mon Feb 10 00:16:12 2025 daemon.err usbmuxd[8786]: [00:16:12.011][3] Using libusb 1.0.24
Mon Feb 10 00:16:12 2025 daemon.err usbmuxd[8786]: [00:16:12.012][3] Initialization complete
Mon Feb 10 00:16:12 2025 daemon.err usbmuxd[8786]: [00:16:12.012][3] Enabled exit on SIGUSR1 if no devices are attached. Start a new instance with "--exit" to trigger.
Mon Feb 10 00:16:13 2025 daemon.err usbmuxd[8786]: [00:16:13.977][3] Caught signal 15, exiting
Mon Feb 10 00:16:13 2025 daemon.err usbmuxd[8786]: [00:16:13.977][3] usbmuxd shutting down
Mon Feb 10 00:16:14 2025 daemon.err usbmuxd[8786]: [00:16:14.077][3] Shutdown complete
Mon Feb 10 00:16:59 2025 kern.notice kernel: [ 100.630118] 7981@C23L3,DfsCacEndUpdate() 3507: [RDM] CAC end. Enable MAC TX.
