GL-MT3000 Version 4.5.0 WGCLIENT Failed to parse json data
I am using wireguard client on GL-MT3000 from last few months and never had problem, last few days I am seeing issue that WG does connect initially but you can able to reach anything and eventually you see below messages:
Tue Feb 20 10:27:00 2024 daemon.notice netifd: wgclient (26547): Warning: fw3_ipt_rule_append(): Can't find match 'connmark'
Tue Feb 20 10:27:00 2024 daemon.notice netifd: wgclient (26547):    * Zone 'lan'
Tue Feb 20 10:27:00 2024 daemon.notice netifd: wgclient (26547):    * Zone 'wan'
Tue Feb 20 10:27:00 2024 daemon.notice netifd: wgclient (26547):    * Zone 'guest'
Tue Feb 20 10:27:00 2024 daemon.notice netifd: wgclient (26547):    * Zone 'wgclient'
Tue Feb 20 10:27:00 2024 daemon.notice netifd: wgclient (26547):  * Set tcp_ecn to off
Tue Feb 20 10:27:00 2024 daemon.notice netifd: wgclient (26547):  * Set tcp_syncookies to on
Tue Feb 20 10:27:00 2024 daemon.notice netifd: wgclient (26547):  * Set tcp_window_scaling to on
Tue Feb 20 10:27:00 2024 daemon.notice netifd: wgclient (26547):  * Running script '/etc/firewall.nat6'
Tue Feb 20 10:27:00 2024 daemon.notice netifd: wgclient (26547):  * Running script '/etc/firewall.swap_wan_in_conn_mark.sh'
Tue Feb 20 10:27:00 2024 daemon.notice netifd: wgclient (26547):  * Running script '/etc/firewall.vpn_server_policy.sh'
Tue Feb 20 10:27:00 2024 daemon.notice netifd: wgclient (26547):  * Running script '/var/etc/gls2s.include'
Tue Feb 20 10:27:00 2024 daemon.notice netifd: wgclient (26547):    ! Skipping due to path error: No such file or directory
Tue Feb 20 10:27:00 2024 daemon.notice netifd: wgclient (26547):  * Running script '/usr/bin/gl_block.sh'
Tue Feb 20 10:27:00 2024 daemon.notice netifd: wgclient (26547): Failed to parse json data: unexpected character
Tue Feb 20 10:27:00 2024 daemon.notice netifd: Network device 'wgclient' link is down
Tue Feb 20 10:27:01 2024 daemon.notice netifd: wgclient (26547): sh: 1: unknown operand
Tue Feb 20 10:27:01 2024 daemon.notice netifd: Interface 'wgclient' is now down
Tue Feb 20 10:27:01 2024 daemon.notice netifd: Interface 'wgclient' is setting up now
Tue Feb 20 10:27:01 2024 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
In another post it is suggested it could be a FW issue but I have checked manually ports being used in the confiiguration it is reachable.
Anyother suggestion why I am seeing this error.
AFAIK, none of these messages are a true issue. Just log noise.
Can you connect to the WG server by using an different device?
@admon : Thanks for ur reply, I suspect the same that there are intermittent problem with the WG Server.
Were you able to get this sorted? I've got the same issue.
What issues?
The original issue is not clear because the log is just normal.
