I have a weird problem with probably a simple solution which now excapes me, please bear with me:
From the internet to my desk, this is the configuration:
ROUTER/MODEM Asus (IP family 192.168.1.x)
managed switch Linksys GS1900-16 (default config, no subnet or anything that is not default); dozens of PC's and devices work attached to any port of this router
secondary unmanaged switch upstairs (tried Zyxel GS1005HP or Netgear GS305P, no difference). There is internet at this switch, and any PC or device that I connect directly to this second switch has internet.
Now, I have another PC that has disabled Wifi, and needs to be behind the VPN of the MT3000 (reason why I bought it). Since the PC has disabled Wifi, I connect it via wire to the LAN port of the MT3000 (IP family 192.168.8.x).
Now I know that I could have the MT3000 to connect to the home Wifi, but it's kind of weak and I prefer a wired connection for performance. The LAN port being already used, I can only use the WAN for this, and from the instruction it seems to be the correct approach.
But here comes the problem: when I connect the MT-3000 to my second switch, via WAN port, every device connected to the switch (and the MT3000) loses the internet ... it goes away. The lights of the switch remaing blinking green, but no internet. Reboot the switch, it may work for a while and then the internet goes away again.
Now the weirdest part: the internet does not go away right away: it may work for a minute, one hour, or even an entire day (work meetings, etc)! But inevitably goes away. And when it does, and I unplug the MT3000, the internet comes back immediately. It's very repeatable, so it's something that has to do with the WAN port of the MT3000 connected to the ports of this second switch.
I tried two different switch brands, but it's exactly the same.
When I eliminate the second switch, connecting the WAN of the MT3000 directly to the main switch, the MT3000 connects and all the other devices attached to the main switch continue to work.
So it seems really like the MT3000 does not like to be connected to the second switch, and when it looses the connection, it knocks off all the other devices of the second switch (but not the main switch)
Has anyone experiened something like this? What is the WAN port for, if not to connect to an existing LAN?
