GL-MT3000 : WiFi DHCP not working for HP SPECTRE-X360 under Win11
exactly as it says in subject:
  • win11 can't obtain DHCP IP over WiFi, neither 2G not 5G.
  • router is in the repeater mode.
  • staticly assigned IP on Win11 works.
please, help
BTW, does it have VPN Kill Switch?
I would like to further confirm that the WiFi of Win11 has been connected to MT3000, cannot obtain DHCP IP, but WiFi is connected, right?
Does the MT3000 enable clients black/white list management?
Is configured a reserved IP for the Win11?
Please share the issue syslog of "Win11 connect to MT3000" through PM and let me know Win11 MAC address. I would like to check the WiFi connection and DHCP interaction through this syslog.
Supported VPN KillSwitch:
in v4.7 and before, called "Block Non-VPN Traffic"
in v4.8 and later versions, called "KillSwitch"
correct
no
yes, but does not make any difference
log with comments follows in PM
thanks, @bruce
