I purchased GL-MT300A over amazon and I can’t connect to the device to configure it.
I can’t enter uboot - steps posted on video at documentation do not work
The device works only as switch/extender, if I connect other’s switch (with internet) cable to WAN and PC to LAN - I can access internet.
Wifi network from label is not found and IP 192.168.8.1 does’t do anything.
Thanks for reply CMagnusJ at least I am not only one affected.
Thanks for info alzhao, however nothing works that you suggested, no ssid - I will try to find hidden ssid when I get home.
Is there a way to flash image via some pins on board? FTDI cable?
I have purchased numerous GL-MT300A and M devices for configuration and selling on to my customers and I have not had any problems so far.
New and straight out of the box it should come up as a router with the lan port and wifi running dhcp on the 192.168.8.x subnet.
If “Out of the Box” this is not the case then most likely you have a rare faulty device.
In my own development I bricked and recovered many times. Remember you must connect your pc to either port but set your pc to the static address of 192.168.1.2 otherwise the uboot ui it will not work.
Unfortunetly nothing works on that device, I ordered second (other) router - the GL-MT300A and it works fine.
Is there a way to flash image/boot via serial of FTDI cable or other way factory reset/flash the device? I might need to sent it back for warranty repair.
