I recently bought a GL-MT300A-Ext for use in an appartment with a public hotspot around. Unfortunately the signal quality inside the room is very poor. Right outside the window the quality is sufficient to get a conection. So I orderd an external outdoor directional antenna (18dBm) with a cable of 4 meters.
Another WiFi repeater is connected to the LAN port of the GL-MT300A-Ext so I don’t have to transmit any signal to the internal network from the GL-MT300A-Ext. Clients connect to the SSID of the repeater. The “internal network” of the GL-MT300A-Ext is turned off.
As the GL-MT300A-Ext has two antennas my question is which antenna has to be replaced for communication with the hotspot?
Is there a dedicated antenna for “internal” and “external” or do I just have to replace just one of them? Do I need to take of the other possible unused antenna?
Thanks for any hint.
BR
Peter Ries
