I think I may have made an incorrect purchase and was hoping somebody could confirm before I swap my GL-MT300A-Ext for the AR150.
I wanted a small router image with the pineapple firmware as I had seen this was possible on the AR150 and also certain TPLink routers and thought with the GL-MT300A-Ext having more RAM and 2 x external antennas that it would be ideal for this. I now realize these have different processors which I suspect make throw a spanner in the works - Is anybody able to verify this.
I understand that to install the nano Firmware on the AR150s that you can follow a process to rebuild the firmware image - Would it be possible to get it working on the GL-MT300A-Ext using this approach.
If not then I’ll cancel my order and get an AR150.
Thanks in advance for any help.
