hessi
Hi folks,
what kind of antenna connectors do the GL-MT300A have?
Is this really a “pure” SMA?
Not RP-SMA?
It’s a little bit difficult to find an outdoor antenna for a caravan with SMA connectors. Most of them have a cable with RP-SMA. :-/
Regards
Michael
justin
2
The MT300A-EXT model SHOULD have normal RP-SMA connectors, which fit on most standard wifi antennas.
I can’t confirm this, so hopefully Alfie can confirm, but the connector should be a standard RP-SMA Male connector such as this: https://www.aerial.net/shop/imageslarge/RP-SMAB.jpg
The standard MT300A model (non-EXT) does not have normal uFL connectors however.
hessi
3
“There is two uFL connectors and two SMA connectors.”
That’s all I found.
Also the OpenWRT-Wiki does not have any information about the antennas.
