I flashed openwrt-mt300a-tor-2.264.bin which seemed to work fine, but I wanted to return to openwrt-mt300a-2.263.bin, so I flashed that.
Now, I get this message when I go to http://192.168.8.1
No page is registered at ‘/webpanel/homepage’.
If this url belongs to an extension, make sure it is properly installed.
If the extension was recently installed, try removing the /tmp/luci-indexcache file.
I tried resetting the device, but it did fix it. Any suggestions? Thanks!
