hi, i have both mt300a and ar300m. using for drone i made into a rover. i kind of chewed up the plastic a bit. i have a 3d printer. do you have an stl file or auto-cad file of the case, for the mt300a and ar300m?
also do you have a diagram that displays the pin-outs for these routers?
they should be posted and readily available. thanks
