Running the latest “semi-official” firmware, version 2.18 (with openvpn support). The directories are now /sys/devices/gpio-leds/leds/gl-mt300a:* . The ‘max_brightness’ file contains 255, so I assume 255 is really the maximal brightness.
Three LEDs: one is always on (couldn’t control that one from the /sys tree), one is controlled by <span style=“line-height: 1.5;”>gl-mt300a:wan/brightness, one is controlled by </span><span style=“line-height: 1.5;”>gl-mt300a:wlan/brightness. There are two more dirs, namely </span><span style=“line-height: 1.5;”>gl-mt300a:lan and </span><span style=“line-height: 1.5;”>gl-mt300a:usb and as far as I can tell, they do nothing.</span>
The LAN LED is fixed as POWER in hardware. So it is always on.
The WAN LED and WiFi leds can be controlled.
The USB LED is actually USB power. The name is not clear. It is used to control the power of USB. When you connect a USB disk and you will see how it will work.
