Hi guys! I can not get the router to the Internet distribution GL MT300N. Connect the modem, it is defined as usb0 devices connected to the laptop via a router the LAN, no internet. Please help to configure the router as well. Log in Annex
How did you set up the modem connection? It you should set up in “Tethering” section, right? The router can get IP from the modem but no Internet connection? You modem should have a separate setup page and you may need to set it up.
I figured out the problem: the ip of the router coincides with the ip of the modem)). Thanks for the quick response!
