Piet
September 9, 2021, 1:03pm
#1
How do I make this setup work?
So I don’t have an external wifi, just an android with cell internet, the router and the chromecast.
The goal is to control the chromecast via phone.
The last thing I tried was to connect the phone via USB to the router but internet via usb did not show up on Android.
How to make this work?
alzhao
September 10, 2021, 9:54am
#2
I think here is something you can try.
Power up the router
Connect your chromecast to the router’s wifi
Enable hotspot on your phone
Connect the router via repeater to your phone
Try to control Chromecast via the phone
Piet
September 10, 2021, 10:22am
#3
Hotspot and wifi don’t work at the same time
alzhao
September 10, 2021, 10:27am
#4
I know. In the steps I didn’t see use the wifi of your phone
Piet
September 10, 2021, 10:28am
#5
Can I make the internet via usb option work? I figured that by “charge only” ivu works, but chromecast does not connect. Do you have a chromecast?
alzhao
September 10, 2021, 10:30am
#6
You can also try USB tethering.
Piet
September 10, 2021, 10:31am
#7
that’s what I mean by internet over usb.
Why bother with the router? Try just phone hotspot and chromecast?
Piet
September 10, 2021, 10:26pm
#10
I was wrong, it DOES work with a hotspot and without an external router. thanks for the hint.
