Hi, All
淘宝上入了一个GL-MT300N,准备刷clean openwrt,想请教大家,刷好之后有没有相关程序可以调用到那个switch button?例如那个按钮向左拨就会自动向openwrt里发出一个命令,向右拨又是另外一个命令
Hi, All
是按照下面这个信息吗?
The MT300N implements a GPIO switch driver, using the scripts below, the switch position can be determined from shell script and acted upon.
/etc/rc.button/BTN_0 /etc/rc.button/BTN_1
The switch uses GPIOs 42 and 43 and can be access by exporting them as inputs. The values correspond to the switch positions as follows.
| Position | GPIO 42 | GPIO 43 |
| Left | High/1 | X |
| Centre | Low/0 | Low/0 |
| Right | X | High/1 |
Where X indicates a "Don't Care" state.
The scripts receive both a button ID in the form "BTN_X" and an action such as "pressed" or "unpressed".
是这个。
你也可以升级到2.261固件。固件里面已经做了相关设置。
我另外问一下,GLI本身的固件何clean openwrt固件有什么区别?我之前的其他设备都是刷的openwrt的固件,用GLI的有什么好处?限制?
好处就是我们开发了界面跟很多配置程序,直接用就好了。
clean固件是什么程序都没有,完全自己装,自己配。对于有洁癖的大牛就用这个。
