Does anyone know how I can get the subversion-client installed on this version of OpenWrt? I see post where it’s available now in trunk, but the only place I see the OpenWrt clean firmware is on the GLI website.
CHAOS CALMER (Chaos Calmer, r47065)
Maybe you can use LEDE.
Download the firmware from the following link.
https://downloads.lede-project.org/releases/17.01.1/targets/ramips/mt7620/
Thank you. I have been hesitant to try LEDE, but since you mentioned it, I tried it and it works great. Thanks for the input.
I’m sure there’s tons on the internet, but in general, is the preference to use LEDE for all of the GLI routers. I have one of the AR300M, MT300N and will probably obtain additional.
Thanks again…
