GL-MT300N has only one radio, it can act as repeater, which means you can connect it to wifi and then connect your devices to its own wifi. It has the problem of “one radio” repeater. You can check this to see how to solve it: Overview - GL.iNet Docs
thanks , I am able to work in repeater mode, but can you also point me to the documentation or some recommendation on which usb wifi dongle works with MT300N.
I do have EDIMAX EW-7811un which is USB wifi dongle based on RTL8188CUS very common, but I am not able install the drivers fully so it does not work. Can you please point me to any documentation on how to add second USB wifi dongle to MT300N.
I never got my question answered for second wifi - so I kept looking for solutions.
built in wifi is using Chipset: Atheros so I ordered usb dongle wifi based on Chipset: Atheros AR9271 paid around $9.00 but cheaper can be found.
after plug in Gl UI did not find it nor Luci - putty to Gl-Mt300N typed wifi detect it found the radio1 and then I cut and paste into wireless file in /etc/config . reboot the GL-MT300N and now Luci shows both the radio and now you can configure now built in one as lan / AP and other one as client/wwan for Wifi of public place .
you should have similar output of wifi detect
config wifi-device ‘radio1’
option type ‘mac80211’
option hwmode ‘11g’
option path ‘101c0000.ehci/usb1/1-1/1-1:1.0’
option htmode ‘HT20’
option txpower ‘20’
option country ‘CN’
option disabled ‘0’
option channel ‘1’
config wifi-iface
options for radio1 …
I know all of above can be done with one radio and use run button script to recover from lock up.
It seemed to work at first, but later I had some speed issues. Some have reported that using a USB cable to put distance between the devices helped. I just went to a Buffalo device, which performed better, but still not as fast as the single radio correctly configured. Definitely easier to manage things with 2 radios.
I had downloaded the package and tried to installed but was getting error at installation , I was not sure if I was doing something wrong . I will try again and post error later this week.
@alzhao - you are right when I was trying to make mine EDIMAX dongle work I had applied the rtl-sdr_2013-06-12_ar71xx.ipk and librtlsdr_2013-06-12_ar71xx.ipk may be that made my AR9271 work - but after your email I reset the router and I had to apply kmod-ath9k-htc and reboot before AR9271 would work again.
When I applied the kmod-ath9k-htc package I did get errors
on every single script of sub packages I get similar error
Collected errors: * pkg_run_script: package “ath9k-htc-firmware” postinst script returned status 255. * opkg_configure: ath9k-htc-firmware.postinst returned 255. *
