I recently upgraded from 2.265 and am getting ready to take this device on a roadtrip where I will be using the hotel’s WiFi as the uplink.
Since the clients will also be wireless, will the radio stop broadcasting the LAN SSID if I am at a new location and didn’t remember to disable the so-called Repeater (uplink) profile?
I remember this being the case with older firmware.
Thanks for letting me know. I suspect that making even other changes via LuCI may confuse your firmware but I was only trying to look at radio stats. I ebentually got them through the command line.
Do you recommend logging in with SSH and using the poweroff command when done with the router instead of just pulling the power cord?
