I am searching for a pre 3.00 version of Gl-mt300n-v2 firmware (maybe 2.7x). Would someone be able to provide me with a valid link please?
Why, will you ask? Well, this is why :
I updated my Gl-mt300n-v2 to version 3.012.
I use purevpn, and since the update, I cannot connect to their service with openvpn anymore.
I tried 3.022 testing version, and I have the same problem.
furthermore, the pptp menu has been removed from this update, but I absolutely need it sometime.
Thank you both for your time. @Leo, I can’t use wireguard with purevpn, and I still need to get pptp working. @heytrey, thanks, the crt must be the reason it doesn’t work in openvpn.
Nevertheless, I still need pptp (@heytrey, purevpn don’t propose their “Netflix” VPN in openvpn), so I still need to downgrade.
The new router package from purevpn includes the crt file, openvpn is therefore working. Thanks @heytrey for your insight.
Nevertheless, I still need to be able to use PPTP, and therefore still need the old 2xxx firmware.
thanks again.
Thanks for your answer @alzhao, but to be honest I don’t care much about security on this device because it is restricted to my “streaming devices” and has no access whatsoever to the rest of my network.
My problem, however, is that I chose this device because it had openvpn and pptp clients embedded, and now I’m stuck with wireguard (which is nice but of no use to me) and no more pptp, which is a serious drawback in usability for me…
that’s why I’m still trying to get the old firmware in spite of its flaws.
thanks anyway
Thanks for that. I downloaded the firmware, but before I update my unit, @kyson-lok or @alzhao, could you confirm that it’s the right one, since it says lede in the name and I thought it was a special version?
