I operate the mango by powerbank or wall plug. unplug when i leave a place
DNS over TLS from Cloudflare is enabled
But I found out that everytime i start up the mango and connect to an exising wifi/hotspot, I cant access the landing page or internet unless I disable DNS over TLS from Cloudflare and then reenable it.
Just letting you know, see if this is a software bug
The portal WiFi need to hijack the domain and redirect you to its login page, if you enabled DNS over TLS, it can’t hijack, so you can’t access the login page. It is an known issue.
