reset to the default config several times, but did not work. the router comes up in the"login enter passwd" page. I can’t get in so don’t know what release the router is on, but probably on the inital release when shipped. thanks!
Depending on your browser, you may have to clear your cache or just type in http://<router ip address>/#/welcome
in manually and complete the setup to configure a router password.
goodlife
is the default wireless password.
If you’ve done a full factory reset, then the first screen is asking you to create a password for the UI.
Cheers.
