Hi, guys.
I have tried NordVPN and ExpressVPN with “GL-MT300N-V2” router, and it works fantastic. Of course it could be faster (Max speed 10Mb with my normal speed 100Mb), but it’s still good results for so small price.
But i have problem with “hide.me”. I used their ovpn file and VPN connected successfully, but after i start browsing internet, it disconnects and not connecting back.
Does someone have same problem? Maybe you found solution for that?
If it helps, i will leave my log files related with VPN:
Sun May 27 09:33:30 2018 daemon.notice openvpn[9465]: OpenVPN 2.4.3 mipsel-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Sun May 27 09:33:30 2018 daemon.notice openvpn[9465]: library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09
Sun May 27 09:33:30 2018 daemon.notice openvpn[9496]: Outgoing Control Channel Authentication: Using 256 bit message hash ‘SHA256’ for HMAC authentication
Sun May 27 09:33:30 2018 daemon.notice openvpn[9496]: Incoming Control Channel Authentication: Using 256 bit message hash ‘SHA256’ for HMAC authentication
Sun May 27 09:33:35 2018 daemon.err openvpn[9496]: RESOLVE: Cannot resolve host address: sofia.hide.me:4000 (Try again)
Sun May 27 09:33:35 2018 daemon.notice openvpn[9496]: Socket Buffers: R=[163840->163840] S=[163840->163840]
Sun May 27 09:33:35 2018 daemon.notice openvpn[9496]: UDP link local: (not bound)
Sun May 27 09:33:35 2018 daemon.notice openvpn[9496]: UDP link remote: [AF_INET]94.156.128.69:4000
Sun May 27 09:33:35 2018 daemon.notice openvpn[9496]: TLS: Initial packet from [AF_INET]94.156.128.69:4000, sid=0a19272d 77a0cf52
Sun May 27 09:33:35 2018 daemon.warn openvpn[9496]: WARNING: this configuration may cache passwords in memory – use the auth-nocache option to prevent this
Sun May 27 09:33:35 2018 daemon.notice openvpn[9496]: VERIFY OK: depth=2, C=MY, ST=Wilayah Persekutuan, L=Labuan, O=eVenture Limited, OU=Certificate Authority, CN=Hide.Me Root CA
Sun May 27 09:33:36 2018 daemon.notice openvpn[9496]: VERIFY OK: depth=1, C=MY, ST=Wilayah Persekutuan, L=Labuan, O=eVenture Limited, OU=Certificate Authority, CN=Hide.Me Server CA #1
Sun May 27 09:33:36 2018 daemon.notice openvpn[9496]: VERIFY KU OK
Sun May 27 09:33:36 2018 daemon.notice openvpn[9496]: Validating certificate extended key usage
Sun May 27 09:33:36 2018 daemon.notice openvpn[9496]: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Sun May 27 09:33:36 2018 daemon.notice openvpn[9496]: VERIFY EKU OK
Sun May 27 09:33:36 2018 daemon.notice openvpn[9496]: VERIFY X509NAME OK: C=MY, ST=Wilayah Persekutuan, L=Labuan, O=eVenture Limited, OU=Certificate Authority, CN=*.hide.me
Sun May 27 09:33:36 2018 daemon.notice openvpn[9496]: VERIFY OK: depth=0, C=MY, ST=Wilayah Persekutuan, L=Labuan, O=eVenture Limited, OU=Certificate Authority, CN=*.hide.me
Sun May 27 09:33:37 2018 daemon.notice openvpn[9496]: Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 8192 bit RSA
Sun May 27 09:33:37 2018 daemon.notice openvpn[9496]: [*.hide.me] Peer Connection Initiated with [AF_INET]94.156.128.69:4000
Sun May 27 09:33:38 2018 daemon.notice openvpn[9496]: SENT CONTROL [*.hide.me]: ‘PUSH_REQUEST’ (status=1)
Sun May 27 09:33:38 2018 daemon.notice openvpn[9496]: PUSH: Received control message: ‘PUSH_REPLY,dhcp-option DNS 94.156.128.68,dhcp-option DNS 94.156.128.70,topology subnet,ping 5,ping-restart 15,explicit-exit-notify,sndbuf 8388608,rcvbuf 8388608,route-gateway 10.3.213.254,redirect-gateway,dhcp-renew,dhcp-release,register-dns,block-outside-dns,client-nat dnat 10.3.213.254 255.255.255.255 10.255.255.254,ifconfig 10.3.213.172 255.255.255.0’
Sun May 27 09:33:38 2018 daemon.err openvpn[9496]: Options error: Unrecognized option or missing or extra parameter(s) in [PUSH-OPTIONS]:11: dhcp-renew (2.4.3)
Sun May 27 09:33:38 2018 daemon.err openvpn[9496]: Options error: Unrecognized option or missing or extra parameter(s) in [PUSH-OPTIONS]:12: dhcp-release (2.4.3)
Sun May 27 09:33:38 2018 daemon.err openvpn[9496]: Options error: Unrecognized option or missing or extra parameter(s) in [PUSH-OPTIONS]:13: register-dns (2.4.3)
Sun May 27 09:33:38 2018 daemon.err openvpn[9496]: Options error: Unrecognized option or missing or extra parameter(s) in [PUSH-OPTIONS]:14: block-outside-dns (2.4.3)
Sun May 27 09:33:38 2018 daemon.notice openvpn[9496]: OPTIONS IMPORT: timers and/or timeouts modified
Sun May 27 09:33:38 2018 daemon.notice openvpn[9496]: OPTIONS IMPORT: explicit notify parm(s) modified
Sun May 27 09:33:38 2018 daemon.notice openvpn[9496]: OPTIONS IMPORT: --sndbuf/–rcvbuf options modified
Sun May 27 09:33:38 2018 daemon.notice openvpn[9496]: Socket Buffers: R=[163840->327680] S=[163840->327680]
Sun May 27 09:33:38 2018 daemon.notice openvpn[9496]: OPTIONS IMPORT: --ifconfig/up options modified
Sun May 27 09:33:38 2018 daemon.notice openvpn[9496]: OPTIONS IMPORT: route options modified
Sun May 27 09:33:38 2018 daemon.notice openvpn[9496]: OPTIONS IMPORT: route-related options modified
Sun May 27 09:33:38 2018 daemon.notice openvpn[9496]: OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Sun May 27 09:33:38 2018 daemon.notice openvpn[9496]: Data Channel Encrypt: Cipher ‘AES-256-CBC’ initialized with 256 bit key
Sun May 27 09:33:38 2018 daemon.notice openvpn[9496]: Data Channel Encrypt: Using 256 bit message hash ‘SHA256’ for HMAC authentication
Sun May 27 09:33:38 2018 daemon.notice openvpn[9496]: Data Channel Decrypt: Cipher ‘AES-256-CBC’ initialized with 256 bit key
Sun May 27 09:33:38 2018 daemon.notice openvpn[9496]: Data Channel Decrypt: Using 256 bit message hash ‘SHA256’ for HMAC authentication
Sun May 27 09:33:38 2018 daemon.notice openvpn[9496]: TUN/TAP device tun0 opened
Sun May 27 09:33:38 2018 daemon.notice openvpn[9496]: TUN/TAP TX queue length set to 100
Sun May 27 09:33:38 2018 daemon.notice openvpn[9496]: do_ifconfig, tt->did_ifconfig_ipv6_setup=0
Sun May 27 09:33:38 2018 daemon.notice openvpn[9496]: /sbin/ip link set dev tun0 up mtu 1500
Sun May 27 09:33:38 2018 daemon.notice openvpn[9496]: /sbin/ip addr add dev tun0 10.3.213.172/24 broadcast 10.3.213.255
Sun May 27 09:33:38 2018 daemon.notice openvpn[9496]: /sbin/ip route add 94.156.128.69/32 via 192.168.1.1
Sun May 27 09:33:38 2018 daemon.notice openvpn[9496]: /sbin/ip route del 0.0.0.0/0
Sun May 27 09:33:38 2018 daemon.notice openvpn[9496]: /sbin/ip route add 0.0.0.0/0 via 10.3.213.254
Sun May 27 09:33:38 2018 daemon.notice openvpn[9496]: Initialization Sequence Completed
Sun May 27 09:34:46 2018 daemon.err openvpn[9496]: event_wait : Interrupted system call (code=4)
Sun May 27 09:34:46 2018 daemon.notice openvpn[9496]: /sbin/ip route del 94.156.128.69/32
Sun May 27 09:34:46 2018 daemon.notice openvpn[9496]: /sbin/ip route del 0.0.0.0/0
Sun May 27 09:34:46 2018 daemon.notice openvpn[9496]: /sbin/ip route add 0.0.0.0/0 via 192.168.1.1
Sun May 27 09:34:46 2018 daemon.notice openvpn[9496]: Closing TUN/TAP interface
Sun May 27 09:34:46 2018 daemon.notice openvpn[9496]: /sbin/ip addr del dev tun0 10.3.213.172/24
Sun May 27 09:34:46 2018 daemon.notice openvpn[9496]: SIGHUP[hard,] received, process restarting
Sun May 27 09:34:46 2018 daemon.notice openvpn[9496]: OpenVPN 2.4.3 mipsel-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Sun May 27 09:34:46 2018 daemon.notice openvpn[9496]: library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09
Sun May 27 09:34:46 2018 daemon.notice openvpn[9496]: Restart pause, 5 second(s)
Sun May 27 09:34:51 2018 daemon.notice openvpn[9496]: Outgoing Control Channel Authentication: Using 256 bit message hash ‘SHA256’ for HMAC authentication
Sun May 27 09:34:51 2018 daemon.notice openvpn[9496]: Incoming Control Channel Authentication: Using 256 bit message hash ‘SHA256’ for HMAC authentication
Sun May 27 09:34:51 2018 daemon.notice openvpn[9496]: TCP/UDP: Preserving recently used remote address: [AF_INET]94.156.128.69:4000
Sun May 27 09:34:51 2018 daemon.notice openvpn[9496]: Socket Buffers: R=[163840->163840] S=[163840->163840]
Sun May 27 09:34:51 2018 daemon.notice openvpn[9496]: UDP link local: (not bound)
Sun May 27 09:34:51 2018 daemon.notice openvpn[9496]: UDP link remote: [AF_INET]94.156.128.69:4000
Sun May 27 09:34:51 2018 daemon.notice openvpn[9496]: TLS: Initial packet from [AF_INET]94.156.128.69:4000, sid=7eff01ce 9783c8e9
Sun May 27 09:34:51 2018 daemon.notice openvpn[9496]: VERIFY OK: depth=2, C=MY, ST=Wilayah Persekutuan, L=Labuan, O=eVenture Limited, OU=Certificate Authority, CN=Hide.Me Root CA
Sun May 27 09:34:51 2018 daemon.notice openvpn[9496]: VERIFY OK: depth=1, C=MY, ST=Wilayah Persekutuan, L=Labuan, O=eVenture Limited, OU=Certificate Authority, CN=Hide.Me Server CA #1
Sun May 27 09:34:51 2018 daemon.notice openvpn[9496]: VERIFY KU OK
Sun May 27 09:34:51 2018 daemon.notice openvpn[9496]: Validating certificate extended key usage
Sun May 27 09:34:51 2018 daemon.notice openvpn[9496]: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Sun May 27 09:34:51 2018 daemon.notice openvpn[9496]: VERIFY EKU OK
Sun May 27 09:34:51 2018 daemon.notice openvpn[9496]: VERIFY X509NAME OK: C=MY, ST=Wilayah Persekutuan, L=Labuan, O=eVenture Limited, OU=Certificate Authority, CN=*.hide.me
Sun May 27 09:34:51 2018 daemon.notice openvpn[9496]: VERIFY OK: depth=0, C=MY, ST=Wilayah Persekutuan, L=Labuan, O=eVenture Limited, OU=Certificate Authority, CN=*.hide.me
Sun May 27 09:34:54 2018 daemon.notice openvpn[9496]: Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 8192 bit RSA
Sun May 27 09:34:54 2018 daemon.notice openvpn[9496]: [*.hide.me] Peer Connection Initiated with [AF_INET]94.156.128.69:4000
Sun May 27 09:34:55 2018 daemon.notice openvpn[9496]: SENT CONTROL [*.hide.me]: ‘PUSH_REQUEST’ (status=1)
Sun May 27 09:34:55 2018 daemon.notice openvpn[9496]: AUTH: Received control message: AUTH_FAILED
Sun May 27 09:34:55 2018 daemon.notice openvpn[9496]: SIGTERM[soft,auth-failure] received, process exiting
