I just upgraded to a Brume, and have a Mango that I would like to use as a wireless access point for it so that my mobile devices can take advantage of the faster VPN speeds and AdGaurd. Unfortunately, I am struggling with the setup process. I would really appreciate some help.
When I go to Network Mode in the Mango and choose Access Point, a message pops up saying that I need to connect it the internet to the WAN port, unlike other access points I have used in the past. After doing that, I receive a second error stating there are LAN IP conflicts. What does this mean? That the access point cannot be on the .8.1 network?
Network situation:
ISP router connected to the WAN port of the Brume, set to a static IP of 192.168.0.90, and a local LAN IP of 192.168.8.1. I then go to an 8 port switch with all my devices connected, most static as .8.2, .8.3, etc. I was thinking that I should connect the Mango directly to the second LAN port of the Brume.
Please ask any questions if more clarification is needed, thanks.
