Hi there,
I have a GL-MT300N-V2 (aka Mango) and I want to use it only as a Wireguard server.
So out of the box I setup DDNS, port forwarding on my router, setup the Wireguard server and I works without problems. But for the management web page I always have to connect to the LAN port or via the wlan of the MT300N. So I want to integrate the device in my home network so that I can access the managment web page from my home network. But this seems to be a little bit tricky. If possible I only want to use wired network and no wireless.
First problem: The WAN port shows now my home network as “Internet”. So my first thought was to setup the WAN port as second LAN port and changed the IP address to a free IP in my router network. But in that case the device always says that it has no internet connection.
Can anyone help me to setup the Mango in my “normal” network so that I can access it and Wireguard server is working?
Thanks a lot,
Thomas
