I was on 13.3 i believe and things were not working . My setup was disconnected for 1 week.
I have a iphone 7
[GL-MT300N-V2) tethering worked well. And when it didnt i would simply unplug and plug back in and i would get the TRUST ?
I no longer get Trust ?
I updated to 13.5.1 , im hoping was not a mistake thinking that it was a necessary update as i try not to update this iphone.
I updated the firmware on the Mango. No go. It says there is no connection when the connect button comes up. And the trust nag no longer appears. Before I upgraded everything same symptoms no TRUST ?
