It is possible to use the LAN port as secondary WAN? I’ve 2 ISP and want to combine in my router.
Thanks
Thanks
You can try to enter advanced page configuration.
Hi Luo,
Can you help me to share step by step how to setup this thing?
It is not so easy to set up two WAN and do load balancing or failover on the router. You need to understand how the configurations work.
But you can find this post as reference.
