I purchased a GL-MT300N-V2 and it was working fantastically with OpenVPN, it was just what I needed. However, I then used the router control panel (accessed by 192.168.8.1) to update the firmware to 2.27. The firmware downloaded fine, and according to the control panel it installed fine also. The router then restarted but has become unresponsive. I can’t even ‘press and hold’ reset to restore factory settings. The lights come on, but no internet access, and I can’t access the control panel (192.168.8.1).
Matt,
Have you follow the procedures to upgrade your firmware?
I used to face the same problem after upgrade firmware because I selected keep current settings when I upgraded it.
Maybe you can try to uboot your router to drbrick it. Here is a article for your reference.
I tried loading this bin with the Uboot gui. Still nothing. By the way this is the bin that I started with which I loaded on the normal gui.
Thanks Alzhao
