BKA
I wish to use the GL-MT300N-V2 (or similar product?) with an antenna on the outside of the motorhome such as the one listed below.
Please is it possible to use the USB port on the router in this way?\
https://www.amazon.com/KUMA-Wireless-Outdoor-Extender-Microsoft/dp/B010Q58N34
Thanks
BKA
alzhao
2
I am not sure if MT300N-V2 works with this one.
It really depends on the drivers. Traditional 3070 and 8187 works. But you’d better use AR150, AR300M or AR750.
MT300N-V2 has a MTK wireless driver and you’d better use it with a 2nd wifi radio.
