Spn
December 28, 2019, 10:45pm
#1
Good Morning,
I’ve tried to update the MT-300N-V2 with this firmware: openwrt-18.06.5-ramips-mt76x8-gl-mt300n-v2-squashfs-sysupgrade.bin
but seems to be bricked…
so I’m trying to recover the router with fast boot functionality, but seems impossible:
Lan Cable in WAN port + reset pressed + power on, releasing the reset button after 3 blink: nothing happen (lan manually configured on 192.168.1.2)
Lan Cable in WAN port + reset pressed + power on, releasing the reset button after 5 blink: nothing happen (lan manually configured on 192.168.1.2)
Lan Cable in LAN port + reset pressed + power on, releasing the reset button after 3 blink: nothing happen (lan manually configured on 192.168.1.2)
Lan Cable in LAN port + reset pressed + power on, releasing the reset button after 5 blink: nothing happen (lan manually configured on 192.168.1.2)
how i can do to enter in fastboot interface recovering my router?
thank you for your help
Luke
Spn
December 29, 2019, 2:17pm
#3
I’ve tryed also with this guide… watching videos… but nothing happen…
I’ve made a video
Video
can anyone help me?
Johnex
December 29, 2019, 2:55pm
#4
In the video you didn’t set the default gateway also.
Set IP to 192.168.1.2 and gateway to 192.168.1.1 and see if it works
Spn
December 29, 2019, 3:48pm
#5
I’ve tryed with your suggestion…
but won’t work again…
Video II
alzhao
December 30, 2019, 10:37am
#6
I checked your video.
You need to keep holding the reset button until the middle LED light up.
Spn
December 30, 2019, 11:17am
#7
Tryed also in this way, but won’t start
(via lan or wan is the same)
Video III
alzhao
December 30, 2019, 11:47am
#8
Pls don’t use ping, it will not answer your ping.
Just use web browser to access the url
Spn
December 30, 2019, 11:53am
#9
but the network icon as shown in the left (near the clock) said no connexion with the router. (network not connected)
I’ve tryed also via browser and no connection
I had similar experience. I pressed the reset button and released after six blinks. Be sure and change the IP as indicated in instructions. I got it to work. Be persistent.
Spn
December 30, 2019, 1:25pm
#11
I’ve tried 100 times … this router blink max 5 times… I’ve tried with ip 192.168.1.2 configured before start the procedure, and after
Nothing change
Plupy
December 30, 2019, 4:46pm
#12
I saw your video. You put patch cable in wan port instead of putting it in the lan port that’s why you can’t log in to Uboot. You should also keep default gateway blank in tcp settings.
Spn
December 30, 2019, 6:05pm
#13
If you see all my videos I’ve tried both lan connection with the same results… wan or lan produce same results
Plupy
December 30, 2019, 7:17pm
#14
Then try using different patch cable.
Johnex
December 31, 2019, 12:22am
#15
Also make sure to use the included power brick or one that can supply at least 2amps. As Plupy wrote, maybe you have a bad lan cable.
alzhao
December 31, 2019, 4:31am
#16
Seems you finally got the procedure correct. But if still not successful maybe just change another computer and lan cable.
The uboot itself should be all the same.
FWIW with my AR150 I let the red led blink six(6) times before releasing the reset button, works every time.
