I upgraded to the firmware of openwrt-mt300n-v2-3.012 version.
But, the web is not accessed after upgrade.
I checked the error log.
root@GL-MT300N-V2:/tmp# cat /var/log/lighttpd/error.log
2019-01-15 07:56:15: (server.c.1412) server started (lighttpd/1.4.48)
2019-01-15 07:56:15: (server.c.1441) WARNING: unknown config-key: url.redirect (ignored)
2019-01-15 07:56:18: (gw_backend.c.331) child exited: 255 unix:/tmp/html.socket-0
2019-01-15 07:56:18: (gw_backend.c.478) unlink /tmp/html.socket-0 after connect failed: Connection refused
2019-01-15 07:56:18: (gw_backend.c.331) child exited: 255 unix:/tmp/api.socket-0
2019-01-15 07:56:18: (gw_backend.c.478) unlink /tmp/api.socket-0 after connect failed: Connection refused
2019-01-15 07:56:19: (gw_backend.c.478) unlink /tmp/api.socket-0 after connect failed: Connection refused
2019-01-15 07:56:19: (gw_backend.c.478) unlink /tmp/html.socket-0 after connect failed: Connection refused
2019-01-15 07:56:20: (gw_backend.c.331) child exited: 255 unix:/tmp/html.socket-0
2019-01-15 07:56:20: (gw_backend.c.478) unlink /tmp/html.socket-0 after connect failed: Connection refused
2019-01-15 07:56:20: (gw_backend.c.331) child exited: 255 unix:/tmp/api.socket-0
2019-01-15 07:56:20: (gw_backend.c.478) unlink /tmp/api.socket-0 after connect failed: Connection refused
I checked fastcgi program.
But, api is terminated immediately.
root@GL-MT300N-V2:/www# ls -la
drwxr-xr-x 4 root root 120 Nov 19 2018 .
drwxr-xr-x 1 root root 0 Jan 1 1970 …
lrwxrwxrwx 1 root root 35 Jan 15 2019 api → /usr/share/glweb1/bin/gl_fcgithread
drwxr-xr-x 2 root root 38 Jan 15 2019 cgi-bin
lrwxrwxrwx 1 root root 33 Jan 15 2019 favicon.ico → /usr/share/glweb1/web/favicon.ico
lrwxrwxrwx 1 root root 29 Jan 15 2019 html → /usr/share/glweb1/bin/gl_html
-rw-rw-r-- 1 root root 495 Jul 26 2018 index.html
drwxrwxr-x 4 root root 49 Jan 15 2019 luci-static
lrwxrwxrwx 1 root root 25 Jan 15 2019 src → /usr/share/glweb1/web/src
root@GL-MT300N-V2:/www# /www/api &
[1]+ Done(255) /www/api
Please let me know what’s wrong.
