GL-MT300N-V2: Lost http and ssh interface even after device reset
with device GL-MT300N-V2
after flashing original openwrt fw openwrt-22.03.5-ramips-mt76x8-glinet_gl-mt300n-v2-squashfs-sysupgrade.bin and after closing myself off interface
How to revert to gl-inet firmware?
Already tried:
Reset to factory with 10 seconds reset button
Reset button while power on until green leds switched on, Uboot flashing Debrick via Uboot - GL.iNet Router Docs 3 with various new and old gl firmwre versions, like:
lede-mt300n-v2-2.26.bin
openwrt-mt300n-v2-3.105.bin
openwrt-mt300n-v2-3.216-0321-1679391429.bin
Soft factory reset at serial console with and without failsafe mode:
firstboot -y && reboot
JFFS2 reset at serial console:
umount /overlay && jffs2reset && reboot
F2Fs reset at serial console:
dd if=/dev/zero of=/dev/loop0 bs=1M; reboot
I can log in to wifi and get IP address 192.168.8.x but can’t access http interface on 192.168.8.1 nor ssh interface
The same using wired lan: i get an IP address but can’t access http interface
I can only access serial console.
What can be done?
Thanks in advance!
root@GL-MT300N-V2:/# netstat -l -n -t tcp
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State
tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:83              0.0.0.0:*               LISTEN
tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN
tcp        0      0 192.168.8.1:53          0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN
tcp        0      0 :::139                  :::*                    LISTEN
tcp        0      0 ::1:53                  :::*                    LISTEN
tcp        0      0 xxxx::xxxx:xxxx:xxxx:xxxx:xx :::*                    LISTEN
tcp        0      0 :::22                   :::*                    LISTEN
tcp        0      0 :::445                  :::*                    LISTEN
(ipv6 address masked)
root@GL-MT300N-V2:/# uci show network
network.loopback=interface
network.loopback.ifname='lo'
network.loopback.proto='static'
network.loopback.ipaddr='127.0.0.1'
network.loopback.netmask='255.0.0.0'
network.globals=globals
network.globals.ula_prefix='xxxx:xxxx:xxxx::/48'
network.lan=interface
network.lan.type='bridge'
network.lan.ifname='eth0.1'
network.lan.proto='static'
network.lan.netmask='255.255.255.0'
network.lan.ip6assign='60'
network.lan.hostname='GL-MT300N-V2-xxx'
network.lan.ipaddr='192.168.8.1'
network.wan=interface
network.wan.ifname='eth0.2'
network.wan.proto='dhcp'
network.wan.hostname='GL-MT300N-V2-xxx'
network.wan_dev=device
network.wan_dev.name='eth0.2'
network.wan_dev.macaddr='x:x:x:x:x:x'
network.wan6=interface
network.wan6.ifname='eth0.2'
network.wan6.proto='dhcpv6'
network.wan6.disabled='1'
network.@switch[0]=switch
network.@switch[0].name='switch0'
network.@switch[0].reset='1'
network.@switch[0].enable_vlan='1'
network.@switch_vlan[0]=switch_vlan
network.@switch_vlan[0].device='switch0'
network.@switch_vlan[0].vlan='1'
network.@switch_vlan[0].ports='1 6t'
network.@switch_vlan[1]=switch_vlan
network.@switch_vlan[1].device='switch0'
network.@switch_vlan[1].vlan='2'
network.@switch_vlan[1].ports='0 6t'
network.guest=interface
network.guest.ifname='guest'
network.guest.type='bridge'
network.guest.proto='static'
network.guest.ipaddr='192.168.9.1'
network.guest.netmask='255.255.255.0'
network.guest.ip6assign='60'
(masked MAC address and wifi SSID)
root@GL-MT300N-V2:/# uci show firewall
firewall.@defaults[0]=defaults
firewall.@defaults[0].syn_flood='1'
firewall.@defaults[0].input='ACCEPT'
firewall.@defaults[0].output='ACCEPT'
firewall.@defaults[0].forward='REJECT'
firewall.@zone[0]=zone
firewall.@zone[0].name='lan'
firewall.@zone[0].network='lan'
firewall.@zone[0].input='ACCEPT'
firewall.@zone[0].output='ACCEPT'
firewall.@zone[0].forward='ACCEPT'
firewall.@zone[1]=zone
firewall.@zone[1].name='wan'
firewall.@zone[1].network='wan' 'wan6'
firewall.@zone[1].input='REJECT'
firewall.@zone[1].output='ACCEPT'
firewall.@zone[1].forward='REJECT'
firewall.@zone[1].masq='1'
firewall.@zone[1].mtu_fix='1'
firewall.@forwarding[0]=forwarding
firewall.@forwarding[0].src='lan'
firewall.@forwarding[0].dest='wan'
firewall.@rule[0]=rule
firewall.@rule[0].name='Allow-DHCP-Renew'
firewall.@rule[0].src='wan'
firewall.@rule[0].proto='udp'
firewall.@rule[0].dest_port='68'
firewall.@rule[0].target='ACCEPT'
firewall.@rule[0].family='ipv4'
firewall.@rule[1]=rule
firewall.@rule[1].name='Allow-Ping'
firewall.@rule[1].src='wan'
firewall.@rule[1].proto='icmp'
firewall.@rule[1].icmp_type='echo-request'
firewall.@rule[1].family='ipv4'
firewall.@rule[1].target='ACCEPT'
firewall.@rule[2]=rule
firewall.@rule[2].name='Allow-IGMP'
firewall.@rule[2].src='wan'
firewall.@rule[2].proto='igmp'
firewall.@rule[2].family='ipv4'
firewall.@rule[2].target='ACCEPT'
firewall.@rule[3]=rule
firewall.@rule[3].name='Allow-DHCPv6'
firewall.@rule[3].src='wan'
firewall.@rule[3].proto='udp'
firewall.@rule[3].src_ip='fc00::/6'
firewall.@rule[3].dest_ip='fc00::/6'
firewall.@rule[3].dest_port='546'
firewall.@rule[3].family='ipv6'
firewall.@rule[3].target='ACCEPT'
firewall.@rule[4]=rule
firewall.@rule[4].name='Allow-MLD'
firewall.@rule[4].src='wan'
firewall.@rule[4].proto='icmp'
firewall.@rule[4].src_ip='fe80::/10'
firewall.@rule[4].icmp_type='130/0' '131/0' '132/0' '143/0'
firewall.@rule[4].family='ipv6'
firewall.@rule[4].target='ACCEPT'
firewall.@rule[5]=rule
firewall.@rule[5].name='Allow-ICMPv6-Input'
firewall.@rule[5].src='wan'
firewall.@rule[5].proto='icmp'
firewall.@rule[5].icmp_type='echo-request' 'echo-reply' 'destination-unreachable' 'packet-too-big' 'time-exceeded' 'bad-header' 'unknown-header-type' 'router-solicitation' 'neighbour-solicitation' 'router-advertisement' 'neighbour-advertisement'
firewall.@rule[5].limit='1000/sec'
firewall.@rule[5].family='ipv6'
firewall.@rule[5].target='ACCEPT'
firewall.@rule[6]=rule
firewall.@rule[6].name='Allow-ICMPv6-Forward'
firewall.@rule[6].src='wan'
firewall.@rule[6].dest='*'
firewall.@rule[6].proto='icmp'
firewall.@rule[6].icmp_type='echo-request' 'echo-reply' 'destination-unreachable' 'packet-too-big' 'time-exceeded' 'bad-header' 'unknown-header-type'
firewall.@rule[6].limit='1000/sec'
firewall.@rule[6].family='ipv6'
firewall.@rule[6].target='ACCEPT'
firewall.@rule[7]=rule
firewall.@rule[7].name='Allow-IPSec-ESP'
firewall.@rule[7].src='wan'
firewall.@rule[7].dest='lan'
firewall.@rule[7].proto='esp'
firewall.@rule[7].target='ACCEPT'
firewall.@rule[8]=rule
firewall.@rule[8].name='Allow-ISAKMP'
firewall.@rule[8].src='wan'
firewall.@rule[8].dest='lan'
firewall.@rule[8].dest_port='500'
firewall.@rule[8].proto='udp'
firewall.@rule[8].target='ACCEPT'
firewall.@include[0]=include
firewall.@include[0].path='/etc/firewall.user'
firewall.@include[0].reload='1'
firewall.gls2s=include
firewall.gls2s.type='script'
firewall.gls2s.path='/var/etc/gls2s.include'
firewall.gls2s.reload='1'
firewall.glfw=include
firewall.glfw.type='script'
firewall.glfw.path='/usr/bin/glfw.sh'
firewall.glfw.reload='1'
firewall.glqos=include
firewall.glqos.type='script'
firewall.glqos.path='/usr/sbin/glqos.sh'
firewall.glqos.reload='1'
firewall.guestzone=zone
firewall.guestzone.name='guestzone'
firewall.guestzone.network='guest'
firewall.guestzone.forward='REJECT'
firewall.guestzone.output='ACCEPT'
firewall.guestzone.input='REJECT'
firewall.guestzone_fwd=forwarding
firewall.guestzone_fwd.src='guestzone'
firewall.guestzone_fwd.dest='wan'
firewall.guestzone_dhcp=rule
firewall.guestzone_dhcp.name='guestzone_DHCP'
firewall.guestzone_dhcp.src='guestzone'
firewall.guestzone_dhcp.target='ACCEPT'
firewall.guestzone_dhcp.proto='udp'
firewall.guestzone_dhcp.dest_port='67-68'
firewall.guestzone_dns=rule
firewall.guestzone_dns.name='guestzone_DNS'
firewall.guestzone_dns.src='guestzone'
firewall.guestzone_dns.target='ACCEPT'
firewall.guestzone_dns.proto='tcp udp'
firewall.guestzone_dns.dest_port='53'
firewall.sambasharewan=rule
firewall.sambasharewan.src='wan'
firewall.sambasharewan.dest_port='137 138 139 445'
firewall.sambasharewan.dest_proto='tcpudp'
firewall.sambasharewan.target='DROP'
firewall.sambasharelan=rule
firewall.sambasharelan.src='lan'
firewall.sambasharelan.dest_port='137 138 139 445'
firewall.sambasharelan.dest_proto='tcpudp'
firewall.sambasharelan.target='ACCEPT'
I even tried to disable firewall, all to no avail:
root@GL-MT300N-V2:/# /etc/init.d/firewall stop
Warning: Section @zone[1] (wan) cannot resolve device of network 'wan6'
Warning: Option 'sambasharewan'.dest_proto is unknown
Warning: Section 'sambasharewan' does not specify a protocol, assuming TCP+UDP
Warning: Option 'sambasharelan'.dest_proto is unknown
Warning: Section 'sambasharelan' does not specify a protocol, assuming TCP+UDP
 * Flushing IPv4 filter table
 * Flushing IPv4 nat table
 * Flushing IPv4 mangle table
 * Flushing IPv6 filter table
 * Flushing IPv6 mangle table
 * Flushing conntrack table ...
This is a correct way to restore glinet firmware.
These steps are not required
But after uboot debrick (mentioned versions) I can access only serial terminal, not http interface nor ssh, so I suppose restore isn’t complete.
How to restore default configuration also?
Can I have gl reference network and firewall config for one of mentioned versions?
(Idk if it’s relevant: in past device history I have tried extroot with last gl fw beta version and it worked, after that I installed openwrt original fw and it worked, after that closed myself off interface and debricked with uboot, uploaded gl fw).
Once the glinet firmware is restored, it is already the default configuration.
Lighttpd(http) and dropbear(ssh) are already running depend on your netstat information ,can you ping 192.168.8.1 through your computer? or can you use another device to access http and ssh?
Solved, was a routing problem not in gl but in my PC and smartphone.
On windows I had to disable Tailscale subnet option.
On Android fixed by itself i don’t know how.
