Ok I was too fast. ttyUSB isnt working anymore, and I dont know why. I just turned on the router and it has no internet connection. It just shows “modem connected” and “connecting to the internet” but nothing happens. I have changed nothing. Just turned off the router for a while and turned it on again. Rebooted the router now a few times, it is not working. logread says:
Sat Nov 11 05:32:03 2017 daemon.info pppd[6108]: Serial connection established.
Sat Nov 11 05:32:03 2017 daemon.info pppd[6108]: Using interface 3g-modem
Sat Nov 11 05:32:03 2017 daemon.notice pppd[6108]: Connect: 3g-modem <–> /dev/ttyUSB0
Sat Nov 11 05:32:04 2017 daemon.notice pppd[6108]: Modem hangup
Sat Nov 11 05:32:04 2017 daemon.notice pppd[6108]: Connection terminated.
Sat Nov 11 05:32:05 2017 daemon.info pppd[6108]: Exit.
Sat Nov 11 05:32:05 2017 daemon.notice netifd: Interface ‘modem’ is now down
Sat Nov 11 05:32:05 2017 daemon.notice netifd: Interface ‘modem’ is setting up now
Sat Nov 11 05:32:07 2017 daemon.notice netifd: modem (6228): Trying to set mode
Sat Nov 11 05:32:08 2017 daemon.notice pppd[6244]: pppd 2.4.7 started by root, uid 0
Sat Nov 11 05:32:09 2017 local2.info chat[6250]: abort on (BUSY)
Sat Nov 11 05:32:09 2017 local2.info chat[6250]: abort on (NO CARRIER)
Sat Nov 11 05:32:09 2017 local2.info chat[6250]: abort on (ERROR)
Sat Nov 11 05:32:09 2017 local2.info chat[6250]: report (CONNECT)
Sat Nov 11 05:32:09 2017 local2.info chat[6250]: timeout set to 10 seconds
Sat Nov 11 05:32:09 2017 local2.info chat[6250]: send (AT&F^M)
Sat Nov 11 05:32:09 2017 local2.info chat[6250]: expect (OK)
Sat Nov 11 05:32:09 2017 local2.info chat[6250]: AT&F^M^M
Sat Nov 11 05:32:09 2017 local2.info chat[6250]: OK
Sat Nov 11 05:32:09 2017 local2.info chat[6250]: – got it
Sat Nov 11 05:32:09 2017 local2.info chat[6250]: send (ATE1^M)
Sat Nov 11 05:32:09 2017 local2.info chat[6250]: ^M
Sat Nov 11 05:32:09 2017 local2.info chat[6250]: ATE1^M^M
Sat Nov 11 05:32:09 2017 local2.info chat[6250]: send (AT+CGDCONT=1,“IP”,“internet”^M)
Sat Nov 11 05:32:09 2017 local2.info chat[6250]: timeout set to 30 seconds
Sat Nov 11 05:32:09 2017 local2.info chat[6250]: AT+CGDCONT=1,“IP”,“internet”^M^M
Sat Nov 11 05:32:09 2017 local2.info chat[6250]: send (ATD99**1#^M)
Sat Nov 11 05:32:10 2017 local2.info chat[6250]: expect (CONNECT)
Sat Nov 11 05:32:10 2017 local2.info chat[6250]: ^M
Sat Nov 11 05:32:10 2017 local2.info chat[6250]: ATD99**1#^M^M
Sat Nov 11 05:32:10 2017 local2.info chat[6250]: CONNECT
Sat Nov 11 05:32:10 2017 local2.info chat[6250]: – got it
Sat Nov 11 05:32:10 2017 local2.info chat[6250]: send ( ^M)
Sat Nov 11 05:32:10 2017 daemon.info pppd[6244]: Serial connection established.
Sat Nov 11 05:32:10 2017 daemon.info pppd[6244]: Using interface 3g-modem
Sat Nov 11 05:32:10 2017 daemon.notice pppd[6244]: Connect: 3g-modem <–> /dev/ttyUSB0
Sat Nov 11 05:32:11 2017 daemon.notice pppd[6244]: Modem hangup
Sat Nov 11 05:32:11 2017 daemon.notice pppd[6244]: Connection terminated.
I tested the stick on the PC and there it is working. I then put it back on the router, and there was a connection for a few moments and now its gone again.
