I have the Mango connected via wifi to my home router.
The Mango keeps on disconnecting from the wifi every 10 to 12 hours and also i can’t see the wifi from the Mango router. it is like it goes to sleep mode, hanging , or something.
as you can see from the picture the power led is always on , but some times it flashes (dont understand what is the difference)
to try to fix this issue i reinstalled the latest firmware after factory resetting, the issue wasn’t resolved.
i thought it might be a bug in the latest firmware , so i factory reset again and downgraded to an older firmware but also the issue still exists.
Please advice what to do , is the hardware faulty??
I disabled cloudfllare , but is that normal that it keeps on crashing when i turn services on (vpn server, cloudflare…etc) ?
the functionality that i bought Mango for is to leave the mango running at home as vpn server , and i connect with BREYL router or pc/phone remotely to access my network remotely.
in my last business trip i was able to connect remotely for the 1st day then the Mango was stuck until i returned back home 4 days later, it was really unreliable and defeated the purpose of buying it!!
the reason for asking if this is a hardware issue, then i will start the processes of replacement/exchange.
