Tudor
December 8, 2024, 2:55am
Hi guys, I've been playing with my Mango router for a bit to test its maximum limits, comparing three different firmware versions. All setups were tested in access point mode with the best quality signal I could achieve (50cm away from AP), so that firewall/other processes wouldn't clog up the CPU/RAM.
With openWRT 23.05.5 pulled from their website ([OpenWrt Wiki] GL.iNet GL-MT300N V2 ) and with openWRT wiki to create an AP only setup, I managed 79mbps down and 80mbps up:
The second test was done using GL.iNet firmware 3.216, managed 54 down 61 up:
And lastly, using GL.iNet firmware 4.3.18, I managed 79 down 56 up at best:
Even going into LuCI and disabling + stopping unnecessary services in acces point mode (firewall, dnsmasq, odhcpd for example), I did not manage to improve speeds up to the clean openWRT firmware standards. My question is, is this firmware still being improved? it feels like it's still got hidden potential. I see a clear improvement from v3 to v4 firmware.
Are you running the speed tests from the shell of the router?
You can try this:
wget https://install.speedtest.net/app/cli/ookla-speedtest-1.2.0-linux-aarch64.tgz && tar xzf ookla-speedtest-1.2.0-linux-aarch64.tgz && ./speedtest
Tudor
December 9, 2024, 5:46pm
3
How would running speedtests from the router shell prove wifi performance?
My ISP speed is 150mbps symmetrical so I'm maxing out the 100mbps LAN in any case.
Hey
the use of iperf3 is very simple and does not require much study I will now go into the use via SSH - presumably the plug-in only takes care of the installation.
On the router
connect to your router via SSH (e.g. ssh root@192.168.177.1)
update the software database: opkg update
install iperf3: opkg install iperf3
start iperf3 in server mode: iperf3 -s
On any client, e.g. Windows:
Download iperf3: iPerf - Download iPerf3 and original iPerf pre-compiled binaries
Connect iper…
run iperf3 on the Mango, then you are testing throughput simply between the Mango and the wireless client running iperf3 to test throughput of the WiFi.
Tudor
December 10, 2024, 4:14pm
5
iperf3 LAN results are worse than speedtest.net but the trend follows my initial statement. All tests performed in best quality wifi, around -30dBm.
Mango in AP mode, reaching iperf server on LAN, stock FW 4.3.18:
C:\Users\MacVM\Desktop\iperf 3.17.1>iperf3 -c 192.168.1.223
Connecting to host 192.168.1.223, port 5201
[ 5] local 192.168.1.32 port 51222 connected to 192.168.1.223 port 5201
[ ID] Interval Transfer Bitrate
[ 5] 0.00-1.02 sec 4.62 MBytes 38.2 Mbits/sec
[ 5] 1.02-2.00 sec 4.12 MBytes 35.1 Mbits/sec
[ 5] 2.00-3.00 sec 4.12 MBytes 34.5 Mbits/sec
[ 5] 3.00-4.00 sec 4.75 MBytes 39.8 Mbits/sec
[ 5] 4.00-5.01 sec 4.00 MBytes 33.5 Mbits/sec
[ 5] 5.01-6.02 sec 3.75 MBytes 30.9 Mbits/sec
[ 5] 6.02-7.01 sec 3.88 MBytes 33.0 Mbits/sec
[ 5] 7.01-8.03 sec 4.50 MBytes 37.1 Mbits/sec
[ 5] 8.03-9.01 sec 4.00 MBytes 34.1 Mbits/sec
[ 5] 9.01-10.03 sec 4.38 MBytes 36.0 Mbits/sec
[ 5] 0.00-10.03 sec 42.1 MBytes 35.2 Mbits/sec sender
[ 5] 0.00-10.04 sec 42.0 MBytes 35.1 Mbits/sec receiver
Reversed, still AP mode... much worse:
C:\Users\MacVM\Desktop\iperf 3.17.1>iperf3 -c 192.168.1.223 -R
Reverse mode, remote host 192.168.1.223 is sending
[ 5] local 192.168.1.32 port 51216 connected to 192.168.1.223 port 5201
[ 5] 0.00-1.01 sec 256 KBytes 2.09 Mbits/sec
[ 5] 1.01-2.00 sec 2.50 MBytes 21.0 Mbits/sec
[ 5] 2.00-3.00 sec 1.62 MBytes 13.6 Mbits/sec
[ 5] 3.00-4.01 sec 2.00 MBytes 16.8 Mbits/sec
[ 5] 4.01-5.01 sec 1.50 MBytes 12.6 Mbits/sec
[ 5] 5.01-6.01 sec 2.50 MBytes 21.0 Mbits/sec
[ 5] 6.01-7.01 sec 3.62 MBytes 30.4 Mbits/sec
[ 5] 7.01-8.01 sec 3.62 MBytes 30.3 Mbits/sec
[ 5] 8.01-9.01 sec 768 KBytes 6.28 Mbits/sec
[ 5] 9.01-10.00 sec 1.88 MBytes 15.8 Mbits/sec
[ 5] 0.00-10.01 sec 20.8 MBytes 17.4 Mbits/sec sender
[ 5] 0.00-10.00 sec 20.2 MBytes 17.0 Mbits/sec receiver
iperf Done.
Iperf internally installed in Mango:
C:\Users\MacVM\Desktop\iperf 3.17.1>iperf3 -c 192.168.1.108 -R
Connecting to host 192.168.1.108, port 5201
Reverse mode, remote host 192.168.1.108 is sending
[ 5] local 192.168.1.32 port 51232 connected to 192.168.1.108 port 5201
[ 5] 0.00-1.00 sec 5.75 MBytes 48.1 Mbits/sec
[ 5] 1.00-2.00 sec 6.50 MBytes 54.5 Mbits/sec
[ 5] 2.00-3.00 sec 6.38 MBytes 53.5 Mbits/sec
[ 5] 3.00-4.00 sec 6.25 MBytes 52.4 Mbits/sec
[ 5] 4.00-5.00 sec 6.62 MBytes 55.6 Mbits/sec
[ 5] 5.00-6.00 sec 8.12 MBytes 68.2 Mbits/sec
[ 5] 6.00-7.00 sec 8.12 MBytes 68.1 Mbits/sec
[ 5] 7.00-8.00 sec 7.88 MBytes 66.0 Mbits/sec
[ 5] 8.00-9.00 sec 8.12 MBytes 68.2 Mbits/sec
[ 5] 9.00-10.00 sec 8.38 MBytes 70.2 Mbits/sec
[ ID] Interval Transfer Bitrate Retr
[ 5] 0.00-10.01 sec 72.9 MBytes 61.1 Mbits/sec 0 sender
[ 5] 0.00-10.00 sec 72.1 MBytes 60.5 Mbits/sec receiver
iperf Done.
Openwrt 23.05.5 installed for this test:
[ 5] local 192.168.1.32 port 51145 connected to 192.168.1.108 port 5201
[ 5] 0.00-1.02 sec 8.62 MBytes 71.2 Mbits/sec
[ 5] 1.02-2.02 sec 9.38 MBytes 78.6 Mbits/sec
[ 5] 2.02-3.00 sec 9.00 MBytes 76.7 Mbits/sec
[ 5] 3.00-4.00 sec 8.88 MBytes 74.4 Mbits/sec
[ 5] 4.00-5.02 sec 8.88 MBytes 73.3 Mbits/sec
[ 5] 5.02-6.00 sec 8.88 MBytes 75.7 Mbits/sec
[ 5] 6.00-7.00 sec 9.12 MBytes 76.5 Mbits/sec
[ 5] 7.00-8.00 sec 9.12 MBytes 76.5 Mbits/sec
[ 5] 8.00-9.00 sec 9.12 MBytes 76.6 Mbits/sec
[ 5] 9.00-10.00 sec 9.00 MBytes 75.4 Mbits/sec
[ 5] 0.00-10.01 sec 90.8 MBytes 76.1 Mbits/sec 0 sender
[ 5] 0.00-10.00 sec 90.0 MBytes 75.5 Mbits/sec receiver
iperf Done.
Try adding -w 4M to the iperf command. I've found that in certain circumstances I get much better results.
system
Closed
June 8, 2025, 6:32pm
7
