GL-MT300N-V2 Mango NordVPN wireguard?
I managed to use this router as a wifi repeater and OpenVPN client on NordVPN but I can't figure out how to configure Wireguard client on it with NordVPN servers, is it possible ? and how ? (documentation seems to be out of date).
NordVPN WireGuard auto configuration is not yet supported on Mango.
If you have another GL router that supports, you may consider copying the configuration file from there and importing it into Mango.
Alternatively, you may use some of the GitHub projects mentioned by other users on the forum to generate a NordVPN WireGuard configuration file.
