GL-MT300N-V2 (Mango) Wi-Fi cannot enable Wi-Fi device
I’ve had a GL-MT300N-V2 (Mango) for a couple of years, but it seems the wireless chip might have an issue.
In the log I see;
Mon Mar 20 07:19:15 2023 daemon.notice procd: /etc/init.d/network: Interface doesn't accept private ioctl...
Mon Mar 20 07:19:15 2023 daemon.notice procd: /etc/init.d/network: set (8BE2): Invalid argument
Mon Mar 20 07:19:15 2023 daemon.notice procd: /etc/init.d/network: mt7628(mt7628): enable failed
All three lights are showing as white.
Any suggestions if this is a hardware fault or what I can do to check, please?
In a second device I see;
The log you posted is system log.
Did you change any wifi settings so that radio cannot be configured? Just do a firmware reset and check again.
You can also send log of kernel?
dmesg
If radio is defective, it will show some message or does not have anything about radio.
Thanks. Log;
# dmesg
[    0.000000] Linux version 4.14.241 (glinet@ubuntu) (gcc version 7.5.0 (OpenWrt GCC 7.5.0 r11257-5090152ae3)) #0 Thu Jul 29 19:50:28 2021
[    0.000000] Board has DDR2
[    0.000000] Analog PMU set to hw control
[    0.000000] Digital PMU set to hw control
[    0.000000] SoC Type: MediaTek MT7628AN ver:1 eco:2
[    0.000000] bootconsole [early0] enabled
[    0.000000] CPU0 revision is: 00019655 (MIPS 24KEc)
[    0.000000] MIPS: machine is GL-MT300N-V2
[    0.000000] Determined physical RAM map:
[    0.000000]  memory: 08000000 @ 00000000 (usable)
[    0.000000] Initrd not found or empty - disabling initrd
[    0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[    0.000000] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x0000000000000000-0x0000000007ffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000007ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000007ffffff]
[    0.000000] On node 0 totalpages: 32768
[    0.000000] free_area_init_node: node 0, pgdat 80505320, node_mem_map 81000040
[    0.000000]   Normal zone: 256 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 32768 pages, LIFO batch:7
[    0.000000] random: get_random_bytes called from start_kernel+0x98/0x494 with crng_init=0
[    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 32512
[    0.000000] Kernel command line: console=ttyS0,115200 rootfstype=squashfs,jffs2
[    0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[    0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[    0.000000] Writing ErrCtl register=0001400f
[    0.000000] Readback ErrCtl register=0001400f
[    0.000000] Memory: 123272K/131072K available (4017K kernel code, 189K rwdata, 928K rodata, 1192K init, 213K bss, 7800K reserved, 0K cma-reserved)
[    0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] NR_IRQS: 256
[    0.000000] intc: using register map from devicetree
[    0.000000] CPU Clock: 575MHz
[    0.000000] timer_probe: no matching timers found
[    0.000000] clocksource: MIPS: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6647862422 ns
[    0.000010] sched_clock: 32 bits at 287MHz, resolution 3ns, wraps every 7469508094ns
[    0.007573] Calibrating delay loop... 380.92 BogoMIPS (lpj=1904640)
[    0.073467] pid_max: default: 32768 minimum: 301
[    0.078167] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.084523] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.097423] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.106913] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.112882] pinctrl core: initialized pinctrl subsystem
[    0.120562] NET: Registered protocol family 16
[    0.151572] mt7621_gpio 10000600.gpio: registering 32 gpios
[    0.157161] mt7621_gpio 10000600.gpio: registering 32 gpios
[    0.162750] mt7621_gpio 10000600.gpio: registering 32 gpios
[    0.173397] clocksource: Switched to clocksource MIPS
[    0.179384] NET: Registered protocol family 2
[    0.183825] IP idents hash table entries: 2048 (order: 2, 16384 bytes)
[    0.190828] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[    0.197581] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[    0.203684] TCP: Hash tables configured (established 1024 bind 1024)
[    0.209939] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.215579] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.221878] NET: Registered protocol family 1
[    0.226102] PCI: CLS 0 bytes, default 32
[    0.229573] Crashlog allocated RAM at address 0x3f00000
[    0.236330] workingset: timestamp_bits=30 max_order=15 bucket_order=0
[    0.248460] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.254080] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[    0.274537] io scheduler noop registered
[    0.278268] io scheduler deadline registered (default)
[    0.284208] gpio-export gpio_export: 1 gpio(s) exported
[    0.289418] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[    0.298409] console [ttyS0] disabled
[    0.301847] 10000c00.uartlite: ttyS0 at MMIO 0x10000c00 (irq = 28, base_baud = 2500000) is a 16550A
[    0.310623] console [ttyS0] enabled
[    0.317612] bootconsole [early0] disabled
[    0.326377] 10000d00.uart1: ttyS1 at MMIO 0x10000d00 (irq = 29, base_baud = 2500000) is a 16550A
[    0.336789] spi-mt7621 10000b00.spi: sys_freq: 191666666
[    0.350375] m25p80 spi0.0: mx25l12805d (16384 Kbytes)
[    0.355616] 4 fixed-partitions partitions found on MTD device spi0.0
[    0.362055] Creating 4 MTD partitions on "spi0.0":
[    0.366937] 0x000000000000-0x000000030000 : "u-boot"
[    0.372900] 0x000000030000-0x000000040000 : "u-boot-env"
[    0.379237] 0x000000040000-0x000000050000 : "factory"
[    0.385318] 0x000000050000-0x000001000000 : "firmware"
[    0.394500] 2 uimage-fw partitions found on MTD device firmware
[    0.400515] Creating 2 MTD partitions on "firmware":
[    0.405626] 0x000000000000-0x0000001a3baf : "kernel"
[    0.411580] 0x0000001a3baf-0x000000fb0000 : "rootfs"
[    0.417487] mtd: device 5 (rootfs) set to be root filesystem
[    0.424902] 1 squashfs-split partitions found on MTD device rootfs
[    0.431193] 0x000000bc0000-0x000000fb0000 : "rootfs_data"
[    0.438335] libphy: Fixed MDIO Bus: probed
[    0.481757] rt3050-esw 10110000.esw: link changed 0x00
[    0.488642] mtk_soc_eth 10100000.ethernet eth0: mediatek frame engine at 0xb0100000, irq 5
[    0.498770] NET: Registered protocol family 10
[    0.507511] Segment Routing with IPv6
[    0.511341] NET: Registered protocol family 17
[    0.515985] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    0.529141] 8021q: 802.1Q VLAN Support v1.8
[    0.544502] VFS: Mounted root (squashfs filesystem) readonly on device 31:5.
[    0.558338] Freeing unused kernel memory: 1192K
[    0.562932] This architecture does not have kernel memory protection.
[    1.692882] init: Console is alive
[    1.696694] init: - watchdog -
[    2.245563] random: fast init done
[    3.961149] rt3050-esw 10110000.esw: link changed 0x01
[    4.766242] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[    5.004281] usbcore: registered new interface driver usbfs
[    5.009949] usbcore: registered new interface driver hub
[    5.015470] usbcore: registered new device driver usb
[    5.027403] exFAT: Version 1.2.9
[    5.066330] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    5.083010] SCSI subsystem initialized
[    5.093032] ehci-platform: EHCI generic platform driver
[    5.108669] phy phy-10120000.usbphy.0: remote usb device wakeup disabled
[    5.115496] phy phy-10120000.usbphy.0: UTMI 16bit 30MHz
[    5.120811] ehci-platform 101c0000.ehci: EHCI Host Controller
[    5.126683] ehci-platform 101c0000.ehci: new USB bus registered, assigned bus number 1
[    5.134842] ehci-platform 101c0000.ehci: irq 26, io mem 0x101c0000
[    5.163448] ehci-platform 101c0000.ehci: USB 2.0 started, EHCI 1.00
[    5.170788] hub 1-0:1.0: USB hub found
[    5.175144] hub 1-0:1.0: 1 port detected
[    5.183091] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    5.191674] ohci-platform: OHCI generic platform driver
[    5.197337] ohci-platform 101c1000.ohci: Generic Platform OHCI controller
[    5.204309] ohci-platform 101c1000.ohci: new USB bus registered, assigned bus number 2
[    5.212430] ohci-platform 101c1000.ohci: irq 26, io mem 0x101c1000
[    5.288368] hub 2-0:1.0: USB hub found
[    5.292700] hub 2-0:1.0: 1 port detected
[    5.300205] uhci_hcd: USB Universal Host Controller Interface driver
[    5.315065] usbcore: registered new interface driver usb-storage
[    5.324550] usbcore: registered new interface driver uas
[    5.330793] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[    5.348744] init: - preinit -
[    6.889955] rt3050-esw 10110000.esw: link changed 0x00
[    7.866051] random: procd: uninitialized urandom read (4 bytes read)
[   10.374958] rt3050-esw 10110000.esw: link changed 0x01
[   11.301648] jffs2: notice: (435) jffs2_build_xattr_subsystem: complete building xattr subsystem, 36 of xdatum (3 unchecked, 33 orphan) and 426 of xref (111 dead, 0 orphan) found.
[   11.320416] mount_root: switching to jffs2 overlay
[   11.406444] overlayfs: upper fs does not support tmpfile.
[   11.418535] urandom-seed: Seeding with /etc/urandom.seed
[   11.621781] procd: - early -
[   11.628262] procd: - watchdog -
[   12.493035] procd: - watchdog -
[   12.503843] procd: - ubus -
[   12.833955] random: ubusd: uninitialized urandom read (4 bytes read)
[   12.845374] random: ubusd: uninitialized urandom read (4 bytes read)
[   12.853659] random: ubusd: uninitialized urandom read (4 bytes read)
[   12.862022] procd: - init -
[   16.563099] kmodloader: loading kernel modules from /etc/modules.d/*
[   16.626698] ntfs: driver 2.1.32 [Flags: R/O MODULE].
[   16.688265] tun: Universal TUN/TAP device driver, 1.6
[   16.746849] ip6_tables: (C) 2000-2006 Netfilter Core Team
[   16.787615] nf_conntrack version 0.5.0 (2048 buckets, 8192 max)
[   17.110013] Netfilter messages via NETLINK v0.30.
[   17.119661] ip_set: protocol 6
[   17.247917] Mirror/redirect action on
[   17.271534] urngd: v1.0.2 started.
[   17.298720] u32 classifier
[   17.301482]     input device check on
[   17.305265]     Actions configured
[   17.369421] GACT probability on
[   17.404644] Simple TC action Loaded
[   17.501242] fuse init (API version 7.26)
[   17.982661] random: crng init done
[   17.986171] random: 6 urandom warning(s) missed due to ratelimiting
[   19.488835]
[   19.488835]
[   19.488835] === pAd = c067c000, size = 1008552 ===
[   19.488835]
[   19.498470] <-- RTMPAllocTxRxRingMemory, Status=0, ErrorValue=0x
[   19.505575] <-- RTMPAllocAdapterBlock, Status=0
[   19.510178] RtmpChipOpsHook(748): Not support for HIF_MT yet!
[   19.516026] mt7628_init()-->
[   19.518952] mt7628_init(FW(8a00), HW(8a01), CHIPID(7628))
[   19.524435] e2.bin mt7628_init(1142)::(2), pChipCap->fw_len(63536)
[   19.530698] mt_bcn_buf_init(289): Not support for HIF_MT yet!
[   19.536528] <--mt7628_init()
[   19.605558] usbcore: registered new interface driver cdc_acm
[   19.611308] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[   19.655247] usbcore: registered new interface driver cdc_wdm
[   19.778602] Ebtables v2.0 registered
[   19.797133] ip_tables: (C) 2000-2006 Netfilter Core Team
[   19.805495] usbcore: registered new interface driver ipheth
[   20.078967] ctnetlink v0.93: registering with nfnetlink.
[   20.543906] usbcore: registered new interface driver usbserial
[   20.549914] usbcore: registered new interface driver usbserial_generic
[   20.556679] usbserial: USB Serial support registered for generic
[   20.639663] wireguard: WireGuard 1.0.20200611 loaded. See www.wireguard.com for information.
[   20.648329] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <[email protected]>. All Rights Reserved.
[   20.854718] xt_time: kernel timezone is -0000
[   20.868629] usbcore: registered new interface driver cdc_ether
[   20.898797] usbcore: registered new interface driver cdc_ncm
[   20.942682] usbcore: registered new interface driver cp210x
[   20.948514] usbserial: USB Serial support registered for cp210x
[   20.995251] usbcore: registered new interface driver huawei_cdc_ncm
[   21.068340] PPP generic driver version 2.4.2
[   21.095212] PPP MPPE Compression module registered
[   21.105285] NET: Registered protocol family 24
[   21.126989] usbcore: registered new interface driver qmi_wwan
[   21.157181] usbcore: registered new interface driver rndis_host
[   21.181117] usbcore: registered new interface driver sierra
[   21.186936] usbserial: USB Serial support registered for Sierra USB modem
[   21.246831] usbcore: registered new interface driver sierra_net
[   21.285879] usbcore: registered new interface driver option
[   21.291621] usbserial: USB Serial support registered for GSM modem (1-port)
[   21.356046] kmodloader: done loading kernel modules from /etc/modules.d/*
[   30.427318] rt3050-esw 10110000.esw: link changed 0x00
[   33.912258] rt3050-esw 10110000.esw: link changed 0x01
[   37.421870] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   38.200534] IPv6: ADDRCONF(NETDEV_UP): lo: link is not ready
[   39.322068] br-lan: port 1(eth0.2) entered blocking state
[   39.327643] br-lan: port 1(eth0.2) entered disabled state
[   39.333551] device eth0.2 entered promiscuous mode
[   39.338418] device eth0 entered promiscuous mode
[   39.511217] br-lan: port 1(eth0.2) entered blocking state
[   39.516757] br-lan: port 1(eth0.2) entered listening state
[   39.614488] br-lan: port 2(eth0.1) entered blocking state
[   39.619979] br-lan: port 2(eth0.1) entered disabled state
[   39.625932] device eth0.1 entered promiscuous mode
[   39.630950] br-lan: port 2(eth0.1) entered blocking state
[   39.636485] br-lan: port 2(eth0.1) entered listening state
[   41.533859] br-lan: port 1(eth0.2) entered learning state
[   41.693471] br-lan: port 2(eth0.1) entered learning state
[   43.613470] br-lan: port 1(eth0.2) entered forwarding state
[   43.619137] br-lan: topology change detected, propagating
[   43.773469] br-lan: port 2(eth0.1) entered forwarding state
[   43.779136] br-lan: topology change detected, propagating
[   44.697645] TX_BCN DESC a6f44000 size = 320
[   44.701957] RX[0] DESC a6f4e000 size = 2048
[   44.706620] RX[1] DESC a6f4f000 size = 1024
[   44.765733] prepare to get e2p access------------
[   44.770800] E2pAccessMode=2
[   44.774638] cfg_mode=9
[   44.777028] cfg_mode=9
[   44.779423] wmode_band_equal(): Band Equal!
[   44.787537] APSDCapable[0]=0
[   44.790457] APSDCapable[1]=0
[   44.793374] APSDCapable[2]=0
[   44.796310] APSDCapable[3]=0
[   44.799226] APSDCapable[4]=0
[   44.802142] APSDCapable[5]=0
[   44.805078] APSDCapable[6]=0
[   44.807996] APSDCapable[7]=0
[   44.810912] APSDCapable[8]=0
[   44.813846] APSDCapable[9]=0
[   44.816764] APSDCapable[10]=0
[   44.819767] APSDCapable[11]=0
[   44.822770] APSDCapable[12]=0
[   44.825786] APSDCapable[13]=0
[   44.828792] APSDCapable[14]=0
[   44.831801] APSDCapable[15]=0
[   44.834820] default ApCliAPSDCapable[0]=0
[   45.181515] Key1Str is Invalid key length(0) or Type(1)
[   45.187005] Key1Str is Invalid key length(0) or Type(1)
[   45.192469] Key1Str is Invalid key length(0) or Type(1)
[   45.198120] Key2Str is Invalid key length(0) or Type(1)
[   45.203603] Key2Str is Invalid key length(0) or Type(1)
[   45.209072] Key2Str is Invalid key length(0) or Type(1)
[   45.214730] Key3Str is Invalid key length(0) or Type(1)
[   45.220198] Key3Str is Invalid key length(0) or Type(1)
[   45.225682] Key3Str is Invalid key length(0) or Type(1)
[   45.231328] Key4Str is Invalid key length(0) or Type(1)
[   45.236813] Key4Str is Invalid key length(0) or Type(1)
[   45.242284] Key4Str is Invalid key length(0) or Type(1)
[   45.277776] load fw image from fw_header_image
[   45.282285] AndesMTLoadFwMethod1(2548)::pChipCap->fw_len(63536)
[   45.288297] FW Version:
[   45.288303] _
[   45.290779] e
[   45.292372] 2
[   45.293977] _
[   45.295573] m
[   45.297167] p
[   45.298762]
[   45.300354]
[   45.301947]
[   45.303552]
[   45.305147]
[   45.308243] FW Build Date:
[   45.308247] 2
[   45.310985] 0
[   45.312579] 1
[   45.314185] 5
[   45.315779] 0
[   45.317372] 6
[   45.318965] 2
[   45.320556] 5
[   45.322150] 2
[   45.323755] 1
[   45.325349] 1
[   45.326941] 4
[   45.328533] 2
[   45.330125] 2
[   45.331718]
[   45.333310]
[   46.110520] CmdSlotTimeSet:(ret = 0)
[   46.600337] CmdAddressLenReq:(ret = 0)
[   46.605062] CmdFwStartReq: override = 1, address = 1048576
[   46.610680] CmdStartDLRsp: WiFI FW Download Success
[   46.628777] MtAsicDMASchedulerInit(): DMA Scheduler Mode=0(LMAC)
[   46.634964] efuse_probe: efuse = 10000012
[   46.639028] RtmpChipOpsEepromHook::e2p_type=2, inf_Type=4
[   46.644523] RtmpEepromGetDefault::e2p_dafault=2
[   46.649118] RtmpChipOpsEepromHook: E2P type(2), E2pAccessMode = 2, E2P default = 2
[   46.656813] NVM is FLASH mode
[   46.659872] 1. Phy Mode = 14
[   46.873957] Country Region from e2p = ffff
[   46.878218] tssi_1_target_pwr_g_band = 33
[   46.882289] 2. Phy Mode = 14
[   46.885356] 3. Phy Mode = 14
[   46.888279] NICInitPwrPinCfg(11): Not support for HIF_MT yet!
[   46.894118] NICInitializeAsic(848): Not support rtmp_mac_sys_reset () for HIF_MT yet!
[   46.902050] mt_mac_init()-->
[   46.904977] MtAsicInitMac()-->
[   46.953631] mt7628_init_mac_cr()-->
[   46.957195] MtAsicSetMacMaxLen(1842): Set the Max RxPktLen=1024!
[   46.963280] <--mt_mac_init()
[   46.966410]  WTBL Segment 1 info:
[   46.969767]          MemBaseAddr/FID:0x28000/0
[   46.973663]          EntrySize/Cnt:32/128
[   46.977106]  WTBL Segment 2 info:
[   46.980463]          MemBaseAddr/FID:0x40000/0
[   46.984360]          EntrySize/Cnt:64/128
[   46.987805]  WTBL Segment 3 info:
[   46.991161]          MemBaseAddr/FID:0x42000/64
[   46.995147]          EntrySize/Cnt:64/128
[   46.998592]  WTBL Segment 4 info:
[   47.001948]          MemBaseAddr/FID:0x44000/128
[   47.006022]          EntrySize/Cnt:32/128
[   47.009546] AntCfgInit(3606): Not support for HIF_MT yet!
[   47.015156] MCS Set = ff ff 00 00 00
[   47.018782] MtAsicSetChBusyStat(1146): Not support for HIF_MT yet!
[   47.025103] [PMF]ap_pmf_init:: apidx=0, MFPC=0, MFPR=0, SHA256=0
[   47.031200] [PMF]RTMPMakeRsnIeCap: RSNIE Capability MFPC=0, MFPR=0
[   47.037490] [PMF]ap_pmf_init:: apidx=1, MFPC=0, MFPR=0, SHA256=0
[   47.043597] [PMF]RTMPMakeRsnIeCap: RSNIE Capability MFPC=0, MFPR=0
[   47.049866] [PMF]ap_pmf_init:: apidx=2, MFPC=0, MFPR=0, SHA256=0
[   47.056016] MtAsicSetRalinkBurstMode(4061): Not support for HIF_MT yet!
[   47.062720] MtAsicSetPiggyBack(1081): Not support for HIF_MT yet!
[   47.117105] MtAsicSetTxPreamble(4040): Not support for HIF_MT yet!
[   47.126792] MtAsicAddSharedKeyEntry(1909): Not support for HIF_MT yet!
[   47.136718] MtAsicAddSharedKeyEntry(1909): Not support for HIF_MT yet!
[   47.143484] MtAsicSetPreTbtt(): bss_idx=0, PreTBTT timeout = 0xf0
[   47.149677] Main bssid = 94:83:c4:15:51:1c
[   47.153936] <==== rt28xx_init, Status=0
[   47.194877] mt7628_set_ed_cca: TURN OFF EDCCA  mac 0x10618 = 0xd7083f0f, EDCCA_Status=0
[   47.203008] WiFi Startup Cost (ra0): 2.500s
[   47.272521] MtAsicSetPreTbtt(): bss_idx=0, PreTBTT timeout = 0x0
[   47.278705] MtAsicSetPiggyBack(1081): Not support for HIF_MT yet!
[   49.293638] tx_kickout_fail_count = 0
[   49.297434] tx_timeout_fail_count = 0
[   49.301146] rx_receive_fail_count = 0
[   49.304909] alloc_cmd_msg = 35
[   49.308001] free_cmd_msg = 35
[   49.391797] TX_BCN DESC a6f44000 size = 320
[   49.396184] RX[0] DESC a6f4e000 size = 2048
[   49.400750] RX[1] DESC a6f4f000 size = 1024
[   49.466422] prepare to get e2p access------------
[   49.471462] E2pAccessMode=2
[   49.475345] cfg_mode=9
[   49.477736] cfg_mode=9
[   49.480130] wmode_band_equal(): Band Equal!
[   49.488250] APSDCapable[0]=0
[   49.491169] APSDCapable[1]=0
[   49.494108] APSDCapable[2]=0
[   49.497025] APSDCapable[3]=0
[   49.499940] APSDCapable[4]=0
[   49.502856] APSDCapable[5]=0
[   49.505786] APSDCapable[6]=0
[   49.508703] APSDCapable[7]=0
[   49.511618] APSDCapable[8]=0
[   49.514548] APSDCapable[9]=0
[   49.517465] APSDCapable[10]=0
[   49.520469] APSDCapable[11]=0
[   49.523490] APSDCapable[12]=0
[   49.526495] APSDCapable[13]=0
[   49.529498] APSDCapable[14]=0
[   49.532503] APSDCapable[15]=0
[   49.535521] default ApCliAPSDCapable[0]=0
[   49.882022] Key1Str is Invalid key length(0) or Type(1)
[   49.887509] Key1Str is Invalid key length(0) or Type(1)
[   49.892973] Key1Str is Invalid key length(0) or Type(1)
[   49.898638] Key2Str is Invalid key length(0) or Type(1)
[   49.904130] Key2Str is Invalid key length(0) or Type(1)
[   49.909595] Key2Str is Invalid key length(0) or Type(1)
[   49.915262] Key3Str is Invalid key length(0) or Type(1)
[   49.920730] Key3Str is Invalid key length(0) or Type(1)
[   49.926223] Key3Str is Invalid key length(0) or Type(1)
[   49.931868] Key4Str is Invalid key length(0) or Type(1)
[   49.937364] Key4Str is Invalid key length(0) or Type(1)
[   49.942836] Key4Str is Invalid key length(0) or Type(1)
[   49.978345] load fw image from fw_header_image
[   49.982855] AndesMTLoadFwMethod1(2548)::pChipCap->fw_len(63536)
[   49.988869] FW Version:
[   49.988875] _
[   49.991350] e
[   49.992942] 2
[   49.994550] _
[   49.996144] m
[   49.997735] p
[   49.999327]
[   50.000921]
[   50.002514]
[   50.004123]
[   50.005719]
[   50.008814] FW Build Date:
[   50.008818] 2
[   50.011556] 0
[   50.013149] 1
[   50.014757] 5
[   50.016352] 0
[   50.017945] 6
[   50.019537] 2
[   50.021131] 5
[   50.022725] 2
[   50.024333] 1
[   50.025927] 1
[   50.027520] 4
[   50.029113] 2
[   50.030705] 2
[   50.032297]
[   50.033905]
[   50.037095] CmdReStartDLRsp: WiFI FW Download Success
[   52.454076] CmdAddressLenReq:(ret = 0)
[   52.458680] CmdFwStartReq: override = 1, address = 1048576
[   52.464345] CmdStartDLRsp: WiFI FW Download Success
[   52.469304] MtAsicDMASchedulerInit(): DMA Scheduler Mode=0(LMAC)
[   52.475426] efuse_probe: efuse = 10000012
[   52.479490] RtmpChipOpsEepromHook::e2p_type=2, inf_Type=4
[   52.484970] RtmpEepromGetDefault::e2p_dafault=2
[   52.489562] RtmpChipOpsEepromHook: E2P type(2), E2pAccessMode = 2, E2P default = 2
[   52.497240] NVM is FLASH mode
[   52.500294] 1. Phy Mode = 14
[   52.769935] Country Region from e2p = ffff
[   52.783916] tssi_1_target_pwr_g_band = 33
[   52.788017] 2. Phy Mode = 14
[   52.791012] 3. Phy Mode = 14
[   52.793964] NICInitPwrPinCfg(11): Not support for HIF_MT yet!
[   52.799788] NICInitializeAsic(848): Not support rtmp_mac_sys_reset () for HIF_MT yet!
[   52.807745] mt_mac_init()-->
[   52.810661] MtAsicInitMac()-->
[   52.870437] mt7628_init_mac_cr()-->
[   52.874071] MtAsicSetMacMaxLen(1842): Set the Max RxPktLen=1024!
[   52.880157] <--mt_mac_init()
[   52.883235]  WTBL Segment 1 info:
[   52.886603]          MemBaseAddr/FID:0x28000/0
[   52.890488]          EntrySize/Cnt:32/128
[   52.893942]  WTBL Segment 2 info:
[   52.897296]          MemBaseAddr/FID:0x40000/0
[   52.901179]          EntrySize/Cnt:64/128
[   52.904633]  WTBL Segment 3 info:
[   52.907987]          MemBaseAddr/FID:0x42000/64
[   52.911959]          EntrySize/Cnt:64/128
[   52.915413]  WTBL Segment 4 info:
[   52.918769]          MemBaseAddr/FID:0x44000/128
[   52.922829]          EntrySize/Cnt:32/128
[   52.926363] AntCfgInit(3606): Not support for HIF_MT yet!
[   52.931964] MCS Set = ff ff 00 00 00
[   52.935605] MtAsicSetChBusyStat(1146): Not support for HIF_MT yet!
[   52.941902] [PMF]ap_pmf_init:: apidx=0, MFPC=0, MFPR=0, SHA256=0
[   52.948011] [PMF]RTMPMakeRsnIeCap: RSNIE Capability MFPC=0, MFPR=0
[   52.954295] [PMF]ap_pmf_init:: apidx=1, MFPC=0, MFPR=0, SHA256=0
[   52.960391] [PMF]RTMPMakeRsnIeCap: RSNIE Capability MFPC=0, MFPR=0
[   52.966673] [PMF]ap_pmf_init:: apidx=2, MFPC=0, MFPR=0, SHA256=0
[   52.972810] MtAsicSetRalinkBurstMode(4061): Not support for HIF_MT yet!
[   52.979528] MtAsicSetPiggyBack(1081): Not support for HIF_MT yet!
[   53.614100] MtAsicSetTxPreamble(4040): Not support for HIF_MT yet!
[   53.623752] MtAsicAddSharedKeyEntry(1909): Not support for HIF_MT yet!
[   53.633653] MtAsicAddSharedKeyEntry(1909): Not support for HIF_MT yet!
[   53.640374] MtAsicSetPreTbtt(): bss_idx=0, PreTBTT timeout = 0xf0
[   53.646594] Main bssid = 94:83:c4:15:51:1c
[   53.650821] <==== rt28xx_init, Status=0
[   53.654751] mt7628_set_ed_cca: TURN OFF EDCCA  mac 0x10618 = 0xd7083f0f, EDCCA_Status=0
[   53.662866] WiFi Startup Cost (ra0): 4.270s
[   53.826349] AP SETKEYS DONE - WPA2, AuthMode(7)=WPA2PSK, WepStatus(6)=AES, GroupWepStatus(6)=AES
[   53.826349]
(part 1 cannot paste it all)
I’d not done anything. We had a power cut, the device is on UPS, but when everything else came up, they could not connect to the AP.
However, it may have previously been working by luck only. What option might have been set so that the radio cannot be configured?
The nuclear option is to reset, but I’d rather not :frowning:
Part 2
[   59.867150] br-lan: port 3(ra0) entered blocking state
[   59.872375] br-lan: port 3(ra0) entered disabled state
[   59.878028] device ra0 entered promiscuous mode
[   59.882722] br-lan: port 3(ra0) entered blocking state
[   59.887983] br-lan: port 3(ra0) entered listening state
[   60.347526] AddTxSType: already registered TxSType (PID = 32, Format = 0
[   60.354559] ##### mbss_cr_enable, BssId = 1
[   61.933480] br-lan: port 3(ra0) entered learning state
[   64.013470] br-lan: port 3(ra0) entered forwarding state
[   64.018872] br-lan: topology change detected, propagating
[   65.120547] br-guest: port 1(ra1) entered blocking state
[   65.126021] br-guest: port 1(ra1) entered disabled state
[   65.131769] device ra1 entered promiscuous mode
[   65.172566] br-guest: port 1(ra1) entered blocking state
[   65.178032] br-guest: port 1(ra1) entered forwarding state
[   65.357547] AddTxSType: already registered TxSType (PID = 32, Format = 0
[   65.364455] AddTxSType: already registered TxSType (PID = 33, Format = 0
[   65.371409] ##### mbss_cr_enable, BssId = 2
[   69.977558] br-lan: port 4(ra2) entered blocking state
[   69.982844] br-lan: port 4(ra2) entered disabled state
[   69.988522] device ra2 entered promiscuous mode
[   69.993246] br-lan: port 4(ra2) entered blocking state
[   69.998514] br-lan: port 4(ra2) entered listening state
[   70.152685] AddTxSType: already registered TxSType (PID = 32, Format = 0
[   70.159592] AddTxSType: already registered TxSType (PID = 33, Format = 0
[   70.166743] br-lan: port 4(ra2) entered disabled state
[   70.259182] AddTxSType: already registered TxSType (PID = 32, Format = 0
[   70.266073] AddTxSType: already registered TxSType (PID = 33, Format = 0
[   70.272995] AddTxSType: already registered TxSType (PID = 34, Format = 0
[   70.279916] ##### mbss_cr_enable, BssId = 2
[   70.284362] br-lan: port 4(ra2) entered blocking state
[   70.289589] br-lan: port 4(ra2) entered listening state
[   71.833675] Rcv Wcid(1) AddBAReq
[   71.837105] Start Seq = 00000000
[   72.333502] br-lan: port 4(ra2) entered learning state
[   74.413450] br-lan: port 4(ra2) entered forwarding state
[   74.418851] br-lan: topology change detected, propagating
[  364.640691] CmdSlotTimeSet:(ret = 0)
[  364.765559] AP SETKEYS DONE - WPA2, AuthMode(7)=WPA2PSK, WepStatus(6)=AES, GroupWepStatus(6)=AES
[  364.765559]
[ 1078.544320] AP SETKEYS DONE - WPA2, AuthMode(7)=WPA2PSK, WepStatus(6)=AES, GroupWepStatus(6)=AES
[ 1078.544320]
[ 1078.639690] Rcv Wcid(3) AddBAReq
[ 1078.643155] Start Seq = 00000000
[ 1653.642288] AP SETKEYS DONE - WPA2, AuthMode(7)=WPA2PSK, WepStatus(6)=AES, GroupWepStatus(6)=AES
[ 1653.642288]
[ 2373.084814] 246, flush one!
[ 2386.589034] 5ec, flush one!
[ 2389.194267] 6d2, flush one!
[ 2389.633972] 6ea, flush one!
[ 2395.137423] 902, flush one!
[ 2438.793440] AddTxSType: already registered TxSType (PID = 33, Format = 0
[ 2438.800368] AddTxSType: already registered TxSType (PID = 34, Format = 0
[ 2438.807564] br-lan: port 3(ra0) entered disabled state
[ 2438.813256] CmdSlotTimeSet:(ret = 0)
[ 2438.825332] AddTxSType: already registered TxSType (PID = 34, Format = 0
[ 2438.832440] br-guest: port 1(ra1) entered disabled state
[ 2439.303828] AddTxSType: already registered TxSType (PID = 32, Format = 0
[ 2439.310751] AddTxSType: already registered TxSType (PID = 34, Format = 0
[ 2439.328503] AddTxSType: already registered TxSType (PID = 34, Format = 0
[ 2439.335537] br-lan: port 3(ra0) entered disabled state
[ 2439.379175] AddTxSType: already registered TxSType (PID = 32, Format = 0
[ 2439.386080] AddTxSType: already registered TxSType (PID = 34, Format = 0
[ 2439.826141] br-lan: port 3(ra0) entered blocking state
[ 2439.831390] br-lan: port 3(ra0) entered listening state
[ 2441.845922] br-lan: port 3(ra0) entered learning state
[ 2442.125149] AP SETKEYS DONE - WPA2, AuthMode(7)=WPA2PSK, WepStatus(6)=AES, GroupWepStatus(6)=AES
[ 2442.125149]
[ 2442.461616] AP SETKEYS DONE - WPA2, AuthMode(7)=WPA2PSK, WepStatus(6)=AES, GroupWepStatus(6)=AES
[ 2442.461616]
[ 2442.522165] Rcv Wcid(2) AddBAReq
[ 2442.525608] Start Seq = 00000000
[ 2443.006478] AddTxSType: already registered TxSType (PID = 32, Format = 0
[ 2443.013514] AddTxSType: already registered TxSType (PID = 33, Format = 0
[ 2443.020375] AddTxSType: already registered TxSType (PID = 34, Format = 0
[ 2443.027348] ##### mbss_cr_enable, BssId = 1
[ 2443.031750] br-guest: port 1(ra1) entered blocking state
[ 2443.037170] br-guest: port 1(ra1) entered forwarding state
[ 2443.925922] br-lan: port 3(ra0) entered forwarding state
[ 2443.931322] br-lan: topology change detected, propagating
[ 2445.751903] CmdSlotTimeSet:(ret = 0)
[ 2445.888089] AP SETKEYS DONE - WPA2, AuthMode(7)=WPA2PSK, WepStatus(6)=AES, GroupWepStatus(6)=AES
[ 2445.888089]
[ 2445.898941] AP SETKEYS DONE - WPA2, AuthMode(7)=WPA2PSK, WepStatus(6)=AES, GroupWepStatus(6)=AES
[ 2445.898941]
[ 2446.619482] AddTxSType: already registered TxSType (PID = 32, Format = 0
[ 2446.626413] AddTxSType: already registered TxSType (PID = 33, Format = 0
[ 2446.633834] br-lan: port 4(ra2) entered disabled state
[ 2446.676975] device ra2 left promiscuous mode
[ 2446.681678] br-lan: port 4(ra2) entered disabled state
[ 2450.999830] Rcv Wcid(1) AddBAReq
[ 2451.003199] Start Seq = 00000000
[ 2453.460113] 107, flush one!
[ 2596.840341] Rcv Wcid(2) AddBAReq
[ 2596.843905] Start Seq = 00000002
[ 2610.560375] Rcv Wcid(2) AddBAReq
[ 2610.563666] Start Seq = 00000000
[ 2614.403422] 574, flush one!
[ 3270.941519] rt3050-esw 10110000.esw: link changed 0x00
[ 3271.428524] AddTxSType: already registered TxSType (PID = 33, Format = 0
[ 3271.435685] br-lan: port 3(ra0) entered disabled state
[ 3271.441350] CmdSlotTimeSet:(ret = 0)
[ 3271.454674] MtAsicSetPreTbtt(): bss_idx=0, PreTBTT timeout = 0x0
[ 3271.460780] MtAsicSetPiggyBack(1081): Not support for HIF_MT yet!
[ 3271.975286] tx_kickout_fail_count = 0
[ 3271.979011] tx_timeout_fail_count = 0
[ 3271.982720] rx_receive_fail_count = 0
[ 3271.986460] alloc_cmd_msg = 13726
[ 3271.989818] free_cmd_msg = 13726
[ 3271.997104] br-guest: port 1(ra1) entered disabled state
[ 3272.324947] TX_BCN DESC a6f44000 size = 320
[ 3272.329258] RX[0] DESC a6f4e000 size = 2048
[ 3272.333890] RX[1] DESC a6f4f000 size = 1024
[ 3272.341565] prepare to get e2p access------------
[ 3272.346670] E2pAccessMode=2
[ 3272.350304] cfg_mode=9
[ 3272.352692] cfg_mode=9
[ 3272.355113] wmode_band_equal(): Band Equal!
[ 3272.363175] APSDCapable[0]=0
[ 3272.366111] APSDCapable[1]=0
[ 3272.369029] APSDCapable[2]=0
[ 3272.371945] APSDCapable[3]=0
[ 3272.374874] APSDCapable[4]=0
[ 3272.377790] APSDCapable[5]=0
[ 3272.380706] APSDCapable[6]=0
[ 3272.383634] APSDCapable[7]=0
[ 3272.386552] APSDCapable[8]=0
[ 3272.389468] APSDCapable[9]=0
[ 3272.392384] APSDCapable[10]=0
[ 3272.395407] APSDCapable[11]=0
[ 3272.398411] APSDCapable[12]=0
[ 3272.401416] APSDCapable[13]=0
[ 3272.404436] APSDCapable[14]=0
[ 3272.407440] APSDCapable[15]=0
[ 3272.410445] default ApCliAPSDCapable[0]=0
[ 3272.756712] Key1Str is Invalid key length(0) or Type(1)
[ 3272.762177] Key1Str is Invalid key length(0) or Type(1)
[ 3272.767827] Key2Str is Invalid key length(0) or Type(1)
[ 3272.773290] Key2Str is Invalid key length(0) or Type(1)
[ 3272.778946] Key3Str is Invalid key length(0) or Type(1)
[ 3272.784423] Key3Str is Invalid key length(0) or Type(1)
[ 3272.790064] Key4Str is Invalid key length(0) or Type(1)
[ 3272.795548] Key4Str is Invalid key length(0) or Type(1)
[ 3272.830525] load fw image from fw_header_image
[ 3272.835054] AndesMTLoadFwMethod1(2548)::pChipCap->fw_len(63536)
[ 3272.841048] FW Version:
[ 3272.841054] _
[ 3272.843540] e
[ 3272.845134] 2
[ 3272.846727] _
[ 3272.848320] m
[ 3272.849913] p
[ 3272.851505]
[ 3272.853097]
[ 3272.854702]
[ 3272.856296]
[ 3272.857891]
[ 3272.860985] FW Build Date:
[ 3272.860989] 2
[ 3272.863737] 0
[ 3272.865330] 1
[ 3272.866923] 5
[ 3272.868515] 0
[ 3272.870109] 6
[ 3272.871701] 2
[ 3272.873293] 5
[ 3272.874897] 2
[ 3272.876491] 1
[ 3272.878085] 1
[ 3272.879676] 4
[ 3272.881268] 2
[ 3272.882862] 2
[ 3272.884568]
[ 3272.886168]
[ 3272.890023] CmdReStartDLRsp: WiFI FW Download Success
[ 3272.896428] CmdAddressLenReq:(ret = 0)
[ 3272.901025] CmdFwStartReq: override = 1, address = 1048576
[ 3272.906696] CmdStartDLRsp: WiFI FW Download Success
[ 3272.911664] MtAsicDMASchedulerInit(): DMA Scheduler Mode=0(LMAC)
[ 3272.917797] efuse_probe: efuse = 10000012
[ 3272.921860] RtmpChipOpsEepromHook::e2p_type=2, inf_Type=4
[ 3272.927343] RtmpEepromGetDefault::e2p_dafault=2
[ 3272.931937] RtmpChipOpsEepromHook: E2P type(2), E2pAccessMode = 2, E2P default = 2
[ 3272.939620] NVM is FLASH mode
[ 3272.942672] 1. Phy Mode = 14
[ 3273.109943] Country Region from e2p = ffff
[ 3273.114225] tssi_1_target_pwr_g_band = 33
[ 3273.118296] 2. Phy Mode = 14
[ 3273.121296] 3. Phy Mode = 14
[ 3273.124247] NICInitPwrPinCfg(11): Not support for HIF_MT yet!
[ 3273.130069] NICInitializeAsic(848): Not support rtmp_mac_sys_reset () for HIF_MT yet!
[ 3273.138013] mt_mac_init()-->
[ 3273.140928] MtAsicInitMac()-->
[ 3273.167826] mt7628_init_mac_cr()-->
[ 3273.171388] MtAsicSetMacMaxLen(1842): Set the Max RxPktLen=1024!
[ 3273.177534] <--mt_mac_init()
[ 3273.180612]  WTBL Segment 1 info:
[ 3273.183975]          MemBaseAddr/FID:0x28000/0
[ 3273.187859]          EntrySize/Cnt:32/128
[ 3273.191303]  WTBL Segment 2 info:
[ 3273.194667]          MemBaseAddr/FID:0x40000/0
[ 3273.198551]          EntrySize/Cnt:64/128
[ 3273.201993]  WTBL Segment 3 info:
[ 3273.205359]          MemBaseAddr/FID:0x42000/64
[ 3273.209330]          EntrySize/Cnt:64/128
[ 3273.212771]  WTBL Segment 4 info:
[ 3273.216139]          MemBaseAddr/FID:0x44000/128
[ 3273.220198]          EntrySize/Cnt:32/128
[ 3273.223733] AntCfgInit(3606): Not support for HIF_MT yet!
[ 3273.229328] MCS Set = ff ff 00 00 00
[ 3273.232952] MtAsicSetChBusyStat(1146): Not support for HIF_MT yet!
[ 3273.239273] [PMF]ap_pmf_init:: apidx=0, MFPC=0, MFPR=0, SHA256=0
[ 3273.245380] [PMF]RTMPMakeRsnIeCap: RSNIE Capability MFPC=0, MFPR=0
[ 3273.251649] [PMF]ap_pmf_init:: apidx=1, MFPC=0, MFPR=0, SHA256=0
[ 3273.257751] [PMF]RTMPMakeRsnIeCap: RSNIE Capability MFPC=0, MFPR=0
[ 3273.264067] MtAsicSetRalinkBurstMode(4061): Not support for HIF_MT yet!
[ 3273.270769] MtAsicSetPiggyBack(1081): Not support for HIF_MT yet!
[ 3273.297890] MtAsicSetTxPreamble(4040): Not support for HIF_MT yet!
[ 3273.307511] MtAsicAddSharedKeyEntry(1909): Not support for HIF_MT yet!
[ 3273.317423] MtAsicAddSharedKeyEntry(1909): Not support for HIF_MT yet!
[ 3273.324157] MtAsicSetPreTbtt(): bss_idx=0, PreTBTT timeout = 0xf0
[ 3273.330348] Main bssid = 94:83:c4:15:51:1c
[ 3273.334603] <==== rt28xx_init, Status=0
[ 3273.338596] mt7628_set_ed_cca: TURN OFF EDCCA  mac 0x10618 = 0xd7083f0f, EDCCA_Status=0
[ 3273.346778] WiFi Startup Cost (ra0): 1.020s
[ 3273.352548] br-lan: port 3(ra0) entered blocking state
[ 3273.357839] br-lan: port 3(ra0) entered listening state
[ 3273.406510] MtAsicSetPreTbtt(): bss_idx=0, PreTBTT timeout = 0x0
[ 3273.412616] MtAsicSetPiggyBack(1081): Not support for HIF_MT yet!
[ 3273.931943] tx_kickout_fail_count = 0
[ 3273.935731] tx_timeout_fail_count = 0
[ 3273.939438] rx_receive_fail_count = 0
[ 3273.943144] alloc_cmd_msg = 36
[ 3273.946259] free_cmd_msg = 36
[ 3273.953206] br-lan: port 3(ra0) entered disabled state
[ 3273.967347] TX_BCN DESC a6f44000 size = 320
[ 3273.971703] RX[0] DESC a6f4e000 size = 2048
[ 3273.976310] RX[1] DESC a6f4f000 size = 1024
[ 3273.984053] prepare to get e2p access------------
[ 3273.989087] E2pAccessMode=2
[ 3273.992723] cfg_mode=9
[ 3273.995128] cfg_mode=9
[ 3273.997527] wmode_band_equal(): Band Equal!
[ 3274.005603] APSDCapable[0]=0
[ 3274.008524] APSDCapable[1]=0
[ 3274.011441] APSDCapable[2]=0
[ 3274.014373] APSDCapable[3]=0
[ 3274.017291] APSDCapable[4]=0
[ 3274.020207] APSDCapable[5]=0
[ 3274.023123] APSDCapable[6]=0
[ 3274.026056] APSDCapable[7]=0
[ 3274.028974] APSDCapable[8]=0
[ 3274.031891] APSDCapable[9]=0
[ 3274.034823] APSDCapable[10]=0
[ 3274.037828] APSDCapable[11]=0
[ 3274.040830] APSDCapable[12]=0
[ 3274.043850] APSDCapable[13]=0
[ 3274.046856] APSDCapable[14]=0
[ 3274.049858] APSDCapable[15]=0
[ 3274.052864] default ApCliAPSDCapable[0]=0
[ 3274.399213] Key1Str is Invalid key length(0) or Type(1)
[ 3274.404696] Key1Str is Invalid key length(0) or Type(1)
[ 3274.410328] Key2Str is Invalid key length(0) or Type(1)
[ 3274.415805] Key2Str is Invalid key length(0) or Type(1)
[ 3274.421441] Key3Str is Invalid key length(0) or Type(1)
[ 3274.426922] Key3Str is Invalid key length(0) or Type(1)
[ 3274.432234] rt3050-esw 10110000.esw: link changed 0x01
[ 3274.437809] Key4Str is Invalid key length(0) or Type(1)
[ 3274.443275] Key4Str is Invalid key length(0) or Type(1)
[ 3274.478226] load fw image from fw_header_image
[ 3274.482734] AndesMTLoadFwMethod1(2548)::pChipCap->fw_len(63536)
[ 3274.488744] FW Version:
[ 3274.488750] _
[ 3274.491224] e
[ 3274.492817] 2
[ 3274.494419] _
[ 3274.496012] m
[ 3274.497604] p
[ 3274.499198]
[ 3274.500791]
[ 3274.502384]
[ 3274.503985]
[ 3274.505579]
[ 3274.508675] FW Build Date:
[ 3274.508679] 2
[ 3274.511416] 0
[ 3274.513008] 1
[ 3274.514612] 5
[ 3274.516204] 0
[ 3274.517795] 6
[ 3274.519387] 2
[ 3274.520980] 5
[ 3274.522572] 2
[ 3274.524175] 1
[ 3274.525768] 1
[ 3274.527362] 4
[ 3274.528955] 2
[ 3274.530546] 2
[ 3274.532138]
[ 3274.533741]
[ 3274.543626] CmdReStartDLRsp: WiFI FW Download Success
[ 3274.658277] CmdAddressLenReq:(ret = 0)
[ 3274.662891] CmdFwStartReq: override = 1, address = 1048576
[ 3274.668560] CmdStartDLRsp: WiFI FW Download Success
[ 3274.673573] MtAsicDMASchedulerInit(): DMA Scheduler Mode=0(LMAC)
[ 3274.679675] efuse_probe: efuse = 10000012
[ 3274.683766] RtmpChipOpsEepromHook::e2p_type=2, inf_Type=4
[ 3274.689236] RtmpEepromGetDefault::e2p_dafault=2
[ 3274.693839] RtmpChipOpsEepromHook: E2P type(2), E2pAccessMode = 2, E2P default = 2
[ 3274.701507] NVM is FLASH mode
[ 3274.704574] 1. Phy Mode = 14
[ 3274.870662] Country Region from e2p = ffff
[ 3274.875151] tssi_1_target_pwr_g_band = 33
[ 3274.879227] 2. Phy Mode = 14
[ 3274.882216] 3. Phy Mode = 14
[ 3274.885434] NICInitPwrPinCfg(11): Not support for HIF_MT yet!
[ 3274.891264] NICInitializeAsic(848): Not support rtmp_mac_sys_reset () for HIF_MT yet!
[ 3274.899240] mt_mac_init()-->
[ 3274.902156] MtAsicInitMac()-->
[ 3274.910896] mt7628_init_mac_cr()-->
[ 3274.914516] MtAsicSetMacMaxLen(1842): Set the Max RxPktLen=1024!
[ 3274.920601] <--mt_mac_init()
[ 3274.923691]  WTBL Segment 1 info:
[ 3274.927046]          MemBaseAddr/FID:0x28000/0
[ 3274.930930]          EntrySize/Cnt:32/128
[ 3274.934385]  WTBL Segment 2 info:
[ 3274.937740]          MemBaseAddr/FID:0x40000/0
[ 3274.941625]          EntrySize/Cnt:64/128
[ 3274.945079]  WTBL Segment 3 info:
[ 3274.948433]          MemBaseAddr/FID:0x42000/64
[ 3274.952405]          EntrySize/Cnt:64/128
[ 3274.955859]  WTBL Segment 4 info:
[ 3274.959213]          MemBaseAddr/FID:0x44000/128
[ 3274.963274]          EntrySize/Cnt:32/128
[ 3274.966806] AntCfgInit(3606): Not support for HIF_MT yet!
[ 3274.972401] MCS Set = ff ff 00 00 00
[ 3274.976042] MtAsicSetChBusyStat(1146): Not support for HIF_MT yet!
[ 3274.982366] [PMF]ap_pmf_init:: apidx=0, MFPC=0, MFPR=0, SHA256=0
[ 3274.988477] [PMF]RTMPMakeRsnIeCap: RSNIE Capability MFPC=0, MFPR=0
[ 3274.994759] [PMF]ap_pmf_init:: apidx=1, MFPC=0, MFPR=0, SHA256=0
[ 3275.000848] [PMF]RTMPMakeRsnIeCap: RSNIE Capability MFPC=0, MFPR=0
[ 3275.007167] MtAsicSetRalinkBurstMode(4061): Not support for HIF_MT yet!
[ 3275.013881] MtAsicSetPiggyBack(1081): Not support for HIF_MT yet!
[ 3275.050766] MtAsicSetTxPreamble(4040): Not support for HIF_MT yet!
[ 3275.060387] MtAsicAddSharedKeyEntry(1909): Not support for HIF_MT yet!
[ 3275.070299] MtAsicAddSharedKeyEntry(1909): Not support for HIF_MT yet!
[ 3275.077036] MtAsicSetPreTbtt(): bss_idx=0, PreTBTT timeout = 0xf0
[ 3275.083263] Main bssid = 94:83:c4:15:51:1c
[ 3275.087520] <==== rt28xx_init, Status=0
[ 3275.091428] mt7628_set_ed_cca: TURN OFF EDCCA  mac 0x10618 = 0xd7083f0f, EDCCA_Status=0
[ 3275.099556] WiFi Startup Cost (ra0): 1.130s
[ 3275.103979] br-lan: port 3(ra0) entered blocking state
[ 3275.109194] br-lan: port 3(ra0) entered listening state
[ 3276.590892] AP SETKEYS DONE - WPA2, AuthMode(7)=WPA2PSK, WepStatus(6)=AES, GroupWepStatus(6)=AES
[ 3276.590892]
[ 3277.123582] br-lan: port 3(ra0) entered learning state
[ 3277.240426] AP SETKEYS DONE - WPA2, AuthMode(7)=WPA2PSK, WepStatus(6)=AES, GroupWepStatus(6)=AES
[ 3277.240426]
[ 3277.308730] Rcv Wcid(2) AddBAReq
[ 3277.312019] Start Seq = 00000000
[ 3278.389941] CmdSlotTimeSet:(ret = 0)
[ 3278.525444] AP SETKEYS DONE - WPA2, AuthMode(7)=WPA2PSK, WepStatus(6)=AES, GroupWepStatus(6)=AES
[ 3278.525444]
[ 3278.536121] AP SETKEYS DONE - WPA2, AuthMode(7)=WPA2PSK, WepStatus(6)=AES, GroupWepStatus(6)=AES
[ 3278.536121]
[ 3279.106564] AddTxSType: already registered TxSType (PID = 32, Format = 0
[ 3279.113734] ##### mbss_cr_enable, BssId = 1
[ 3279.118144] br-guest: port 1(ra1) entered blocking state
[ 3279.123567] br-guest: port 1(ra1) entered forwarding state
[ 3279.203634] br-lan: port 3(ra0) entered forwarding state
[ 3279.209035] br-lan: topology change detected, propagating
[ 3279.262715] flush result = ffffff
[ 3279.266147] check pse fid Q7:
[ 3279.266163] pkt:0, fid:169, dw_idx = 0, dw_content = 0x38000103
[ 3279.275174] pkt:0, fid:169, dw_idx = 1, dw_content = 0x8cc00
[ 3279.280918] pkt:0, fid:169, dw_idx = 2, dw_content = 0xa0000408
[ 3279.286927] pkt:0, fid:169, dw_idx = 3, dw_content = 0xc07bf840
[ 3279.292925] pkt:0, fid:169, dw_idx = 4, dw_content = 0x7b
[ 3279.298407] pkt:0, fid:169, dw_idx = 5, dw_content = 0x1420
[ 3279.304067] pkt:0, fid:169, dw_idx = 6, dw_content = 0xc00
[ 3279.309625] pkt:0, fid:169, dw_idx = 7, dw_content = 0x0
[ 3282.897238] AddTxSType: already registered TxSType (PID = 32, Format = 0
[ 3282.904630] br-guest: port 1(ra1) entered disabled state
[ 3282.919973] AddTxSType: already registered TxSType (PID = 32, Format = 0
[ 3282.926861] AddTxSType: already registered TxSType (PID = 33, Format = 0
[ 3282.933759] ##### mbss_cr_enable, BssId = 1
[ 3282.938151] br-guest: port 1(ra1) entered blocking state
[ 3282.943577] br-guest: port 1(ra1) entered forwarding state
[ 3288.531021] Rcv Wcid(1) AddBAReq
[ 3288.534442] Start Seq = 00000000
[ 3363.165998] Rcv Wcid(2) AddBAReq
[ 3363.169574] Start Seq = 00000000
[ 3369.133340] Rcv Wcid(2) AddBAReq
[ 3369.136630] Start Seq = 00000001
[ 3972.275326] Rcv Wcid(2) AddBAReq
[ 3972.278725] Start Seq = 00000002
[ 5047.259234] 788, flush one!
[ 7020.100571] AP SETKEYS DONE - WPA2, AuthMode(7)=WPA2PSK, WepStatus(6)=AES, GroupWepStatus(6)=AES
[ 7020.100571]
[ 7020.111169] AP SETKEYS DONE - WPA2, AuthMode(7)=WPA2PSK, WepStatus(6)=AES, GroupWepStatus(6)=AES
[ 7020.111169]
[ 7020.144291] AP SETKEYS DONE - WPA2, AuthMode(7)=WPA2PSK, WepStatus(6)=AES, GroupWepStatus(6)=AES
[ 7020.144291]
[ 7020.170791] AP SETKEYS DONE - WPA2, AuthMode(7)=WPA2PSK, WepStatus(6)=AES, GroupWepStatus(6)=AES
[ 7020.170791]
[ 7022.149089] MtAsicAddSharedKeyEntry(1909): Not support for HIF_MT yet!
[ 7022.155745] MtAsicAddSharedKeyEntry(1909): Not support for HIF_MT yet!
[ 7792.399862] 47a, flush one!
It seems that the radio is OK.
Can you post content of your /etc/config/wireless?
Pls mark your wifi key when you post the content.
Great, can you tell me which message told you that please?
# cat /etc/config/wireless
config wifi-device 'mt7628'
        option type 'mt7628'
        option ht_txstream '2'
        option ht_rxstream '2'
        option noscan '0'
        option txpower '20'
        option txpower_max '20'
        option country 'US'
        option region '0'
        option band '2G'
        option mimops '3'
        option wmm '1'
config wifi-iface 'wifinet0'
        option device 'mt7628'
        option mode 'ap'
        option wds '1'
        option disassoc_low_ack '0'
        option ifname 'ra0'
        option ssid 'IOTLANW'
        option network 'lan'
        option disabled '0'
        option hidden '0'
        option key '********'
        option encryption 'psk2'
config wifi-iface 'guest2g'
        option network 'guest'
        option mode 'ap'
        option wds '1'
        option ssid 'GL-MT300N-V2-11c-Guest'
        option key '**************'
        option ifname 'ra1'
        option guest '1'
        option flag '1'
I just compare the log with mine.
But in your config you don’t have channel configured. As long as I know, channel is a must.
How do I do that? There isn’t a radio to associate it with as the device is not active.
On the other UI
I have reset the router, upgraded the firmware and I get the same view as above (Device is not Active).
I can connect to the router wirelessly with a laptop, which is extremely strange. My other devices cannot.
[edit]
Some more tests, I am seeing this error, so tested directly
root@GL-MT300N-V2:~# /sbin/wifi
mt7628(mt7628): disable failed
What argument could be invalid?
Current config (after reset, update and enabling Luci) - no other changes
root@GL-MT300N-V2:~# cat /etc/config/wireless
        option htmode 'HT40'
        option hwmode '11g'
        option noscan '0'
        option txpower '20'
        option country 'GB'
        option region '0'
        option band '2G'
        option mimops '3'
        option wmm '1'
        option channel '11'
        option mode 'ap'
        option key 'goodlife'
        option ssid 'GL-MT300N-V2-11c'
        option wds '1'
        option ifname 'ra0'
        option mode 'ap'
        option wds '1'
        option ifname 'ra1'
        option disabled '1'
        option guest '1'
Pretty convinced this is a bug due to the use of OpenWrt v19.07 by OEM. Loaded V22.03 and it is fine.
The default firmware should work fine. Otherwise a lot of users will screem.
Can I ask if it works after you reset and just do initialization without install luci etc? Luci will change some configurations. Also I saw that you changed to country to GB but this model actually use the region option.
By V22.03 you installed a full open source version with open source wifi driver.
It might work, but it doesn’t mean there aren’t errors.
It works without Luci, in that in basic configuration I can connect to the AP, but I can’t configure it correctly as I need to set up a VLAN and that requires Luci as well as some other configuration changes.
I’m simply clicking on the ‘Advanced’ mode, then ‘Wireless’ so I am not doing anything you do not supply out of the box.
I was just trying different things.
I still think my first post, and the system log error is the issue.
I checked mine, firmware 3.215.
In luci it shows “Device is not active”, which I think it is normal. The wifi still works OK.
This is because MT300N-V2 Mango uses MTK private wifi driver and Luci is not compatible.
In your another device you’d better check what firmware you installed. Maybe you uses firmware downloaded from OpenWrt directly and Luci is just fine with with wifi.
