I want to connect cellular 3G/4G modem to mango mini router.
I first tried with a random USB modem and I got only tethering mode working, no cellular. I can access Internet but this is not good enought because the router IP address is a private one and I need to have public IP address.
Then I found on gl-inet documentation this list that reveals some compatible USB modems. Cellular - GL.iNet Router Docs 4
I therefore bought a new USB modem from the list : Huawei E3276
But unfortunately, cellular connexion is still not working. Only Tethering mode works.
On web interface it's still said : "No Modem device found. Plug in your USB modem to start."
Note : The GL inet list precises some models with only tethering working : "*Host-less: This modem supports tethering mode, please set up by using Tethering but not 3G/4G modem."
So it looks this is a regular issue on routers.
Note : I've rebooted the router many times
Would you have any recommendation that can help ?
Thank you !!
Hanna
