I have a GL-MT300N-V2 setup to connect using the Surfshark openVPN config file. It connects with no errors but the VPN doesn’t seem to be connected. Whatsmyip, DNS leak, and webRTC tests all fail while the connection is up. It doesn’t matter if I’m connecting the mango to my local network via wifi or eth. It’s running 3.211
Are you able to “ping 8.8.8.8” ?
I think I just figured it out.
The VPN rule was set to only allow the Ip range 192.168.8.1/24 I deleted that and just left it blank, which made the default “all website”. Works like a charm now…???
This is confirmation, right?
