I have had this GL-MT300N-V2 router for a few years and have used the OpenVPN client successfully for most of that time. However, it has stopped working recently. I just did a firmware refresh in case there were problems with compatibility on old settings with updated firmware settings. No joy.
The cert was created through the openssl tools. I know the certificate still works because I can connect with the same certificate on other devices. Certificate information (with appropriate redactions) follows:
verb 3
nobind
dev tun
client
askpass
remote 1194 udp
fast-io
compress lzo
remote-cert-tls server
-----BEGIN OpenVPN Static key V1-----
Redacted
-----END OpenVPN Static key V1-----
-----BEGIN CERTIFICATE-----
Redacted
-----END CERTIFICATE-----
Redacted
-----BEGIN ENCRYPTED PRIVATE KEY-----
Redacted
-----END ENCRYPTED PRIVATE KEY-----
daemon
up /etc/openvpn/update-resolv-conf
down /etc/openvpn/update-resolv-conf
script-security 2
