Greetings all.
Of the two low cost lower end travel routers I’ve been playing with, one is the GL-MT300N-V2 the other GL-ARM300M.
There was a previous thread located here by another user, entitled similarly to mine, that addressed some of my questions, but not all:
My primary use case is not concerned with WiFi nor running a VPN directly on these devices. There’ll be one computer connected to the router via an Ethernet cable. What’s more important are aspects of throughput, latency, routing speeds, and not dropping packets. With that said, if I were to choose one of the two options listed in the title of my message, which one would fit the use case I’ve outlined?
