Hello All,
Just got a GL-MT300N-V2 (referred as GL onwards) and connected it to my Orbi RBR50 (referred as Orbi onwards) via WAN so connection is as follows:
GL WAN Port → Orbi Ethernet Port (CAT 6 Cable)
GL MicroUsb → Orbi USB Port (For Power)
Without GL my Orbi download speed is around 540Mbps. However, once I connect the GL to Orbi as mentioned above the GL only gives around 60Mbps. On the specs it should give atleast 300Mbps max.
Is my connections wrong or any settings need to be changed @ 192.168.8.1 page?
Any help is greatly appreciated.
