My router ip is 192.168.178.50
I opened port 34091
I defined a new port forwarding roule
From wan port 34091 to internal lan address 192.168.178. 3 at port 80.
I have the same problem that port forwarding doesn’t work running V3.104
I can open the ssh port on the WAN interface and ssh to the MT300 at its WAN port 22. From that MT3000 cmd line session I can ssh to my server at 192.168.8.196.
I have created a port forwarding rule to forward WAN port 8022 to LAN 192.168.8.196:22 but a connection to WAN:8022 times out.
I have tried using DMZ to forward all ports, but that doesn’t work either.
So I have disabled DMZ and open port 22 works but forwarded port 8022 doesn’t connect.
Of course I have a solution for ssh connections, but I want to forward WAN:8080 to LAN 192.168.8.196:80, and that doesn’t work.
Oops, pilot IP address errors on my part. So “Nevermind”
Router 1 Connected to Internet optical fiber
192.168.178.1
Router 2 Connected to router 1 via WAN port defined as LAN
192.168.50
Other equipmnet with web interface
192.168.178.3
I defined port forwarding roule on “Advanced” menu’s in Mango
Port 34091 → 192.168.178.3 Port 80
If i surf to 192.168.178.50:34091 No response
I defined a vpn profile but the problema arise both connected to vpn and disconnected to vpn.
Router 2, when defined WAN as LAN, it is still working in router mode. This is useful when you use the router as Repeater or use it without Internet.
But you cannot connect cable to Router 1 as this will mess up everything. Router 2, working in router mode, still has DHCP server enabled. It could issue IP address to your other devices in your main router which may break your main network.
If you want to bridge everything to your main router, you need to set Router 2 in AP mode (more settings->network mode). This will disable DHCP and firewall.
You can NOT use VPN in AP mode. You can NOT use firewall in AP mode.
In your network settings, though not correct, may still work. If you have a server at 178.3, you may just need to access it via your main network. No need to set up port forward. 178.3 is connect to 178.1 directly so if you want to access it from Internet, you need to set up port forward in Router 1.
When you connect one computer, e.g. one NAS or PC, to router2, they will goes to VPN server. So you cannot access them from Router1. Even with port forward.
