I have GL-MT300N-V2 latest firmware. surfshark vpn wont connect using the openvpn client.
I have tried privatevpn provider which works fine. I am wondering is it a surfshark config issue or firmware issue with the GL-MT300N-V2. Any help would be appreciated.
I’ve got the same router connected succesfully to Surfshark. The tricky thing is that you need to use a separate password that you can get from the Surfshark website. This is not the same as the login you use to get to the surfshark site itself…
