GL-MT300N-V2 to OPNSense OPENVPN
Hello everyone, we've had this MT300 v2 router here for almost a month now, which is supposed to connect to Opnsense using opnvpn. It seems that NOBODY has a problem configuring it; it just doesn't work for us. Meanwhile, we need someone neutral to come up with a new approach. I'm sharing the log with you.
Mon Mar 24 10:34:42 2025 daemon.notice ovpnclient[14643]: UDP link local (bound): [AF_INET][undef]:0
Mon Mar 24 10:34:42 2025 daemon.notice ovpnclient[14643]: UDP link remote: [AF_INET]185.154.67.17:1194
Mon Mar 24 10:35:43 2025 daemon.err ovpnclient[14643]: TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Mon Mar 24 10:35:43 2025 daemon.err ovpnclient[14643]: TLS Error: TLS handshake failed
Mon Mar 24 10:35:43 2025 daemon.notice ovpnclient[14643]: SIGHUP[soft,tls-error] received, process restarting
Mon Mar 24 10:35:43 2025 daemon.notice ovpnclient[14643]: OpenVPN 2.5.7 mipsel-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Mon Mar 24 10:35:43 2025 daemon.notice ovpnclient[14643]: library versions: OpenSSL 1.1.1t 7 Feb 2023, LZO 2.10
Mon Mar 24 10:35:48 2025 daemon.warn ovpnclient[14643]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Mon Mar 24 10:35:48 2025 daemon.notice ovpnclient[14643]: TCP/UDP: Preserving recently used remote address: [AF_INET]185.154.67.17:1194
Mon Mar 24 10:35:48 2025 daemon.notice ovpnclient[14643]: UDP link local (bound): [AF_INET][undef]:0
Mon Mar 24 10:35:48 2025 daemon.notice ovpnclient[14643]: UDP link remote: [AF_INET]185.154.67.17:1194
Mon Mar 24 10:36:48 2025 daemon.err ovpnclient[14643]: TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Mon Mar 24 10:36:48 2025 daemon.err ovpnclient[14643]: TLS Error: TLS handshake failed
Mon Mar 24 10:36:48 2025 daemon.notice ovpnclient[14643]: SIGHUP[soft,tls-error] received, process restarting
Mon Mar 24 10:36:48 2025 daemon.notice ovpnclient[14643]: OpenVPN 2.5.7 mipsel-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Mon Mar 24 10:36:48 2025 daemon.notice ovpnclient[14643]: library versions: OpenSSL 1.1.1t 7 Feb 2023, LZO 2.10
Mon Mar 24 10:36:53 2025 daemon.warn ovpnclient[14643]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Mon Mar 24 10:36:53 2025 daemon.notice ovpnclient[14643]: TCP/UDP: Preserving recently used remote address: [AF_INET]185.154.67.17:1194
Mon Mar 24 10:36:53 2025 daemon.notice ovpnclient[14643]: UDP link local (bound): [AF_INET][undef]:0
Mon Mar 24 10:36:53 2025 daemon.notice ovpnclient[14643]: UDP link remote: [AF_INET]185.154.67.17:1194
The issue is here
Check if your config is still valid, your CA is correct and OVPN isn't blocked.
I take the same ovpn file, the config, and use it for openvpn, where it works perfectly
How does your network topology looks like?
Our topology is actually nothing special, especially since that's exactly what we want to test. The iNET router is configured with the default settings (192.168.8.0/24), and we've inserted the exported OPNSense ovpn file into it. Our network is 192.168.16.0/24, with OPNSense as the firewall, and we want to establish a C2S connection with the device.
Do you try from inside your network or by using another internet connection?
always another connection,... i tried from home or with a hotspot
If you use the OVPN client on a device like a PC, will it work from this connect then?
yes, this works perfect
no idea?
