Hi everyone,
in latest Release Notes for my GL-MT300N-V2 it says “Added Tor function (currently support custom installation)”: https://docs.gl-inet.com/en/3/release_notes/gl-mt300n-v2/
What do I have to do to add this Tor function? Because it still doesn’t show up under “VPN”:
Go to applications → plugins, refresh the repo and install gl-tor
Because the 16MB flash is so limited so we cannot put Tor in the default firmware. Before you install Tor, do not put other files like uploading a lot of ovpn files to the router. After install tor you will likely still have several hundreds of Bytes to use.
