Hello. I recently bought and configured a GL-MT300N-V2 and I’m unable to connect to wi-fi most of the time. The router simply rejects the wi-fi password and give an error of “Incorrect password” and then prompts me for the password (which doesn’t work). After unplugging the router from power and repowering it (usually multiple times) it eventually allows me to connect. But then if I test it again, the problem returns. This is a huge problem for a travel router! I’ve tried resetting the setting and reconfiguring it multiple times and the problem persists. I’ve tried connecting from different wireless devices with the same result. I also tried it in a different location (this was actually during a trip and I was unable to use it even after numerous resets) so it’s not an environmental issue. I’ve also tried various power supplies and the problem persists. Finally, I replaced the unit with a brand new one which did not fix the issue either.
To clarify, this is a custom wi-fi password that I set, not the default. If I reset the router to factory setting the default password works fine.
Has anyone experienced anything like this?
Thanks in advance for any help!
