Wireguard client on GL-MT300N-V2 (firmware 4.3.7) does not work.
I am hosting my own wireguard server on digital ocean droplet, other GL routers my family possesses GL-A1300 Slate Plus, 2 x Flint (GL-AX1800), Opal (GL-SFT1200) work with that wireguard server without any issues (I am aware that each client should have separate configuration, and for each router I have separate one).
I tried but it did not help:
- Install another firmaware : 3.216 and 4.3.11
- Remove ListenPort, and lower MTU to 1300
- I checked the router configuration file on my phone wireguard app and it works there fine without any issues (I did not forget to turn it off after check).
- I have tried to do this on the router as well
iptables -I FORWARD -j ACCEPT
VPN log:
Sun Jun 30 12:20:04 2024 daemon.notice netifd: Interface 'wgclient' is now up
Sun Jun 30 12:20:10 2024 user.notice wgclient-up: env value:T_J_V_ifname=string J_V_address_external=1 USER=root ifname=wgclient ACTION=KEYPAIR-CREATED N_J_V_address_external=address-external SHLVL=2 J_V_keep=1 HOME=/ HOTPLUG_TYPE=wireguard T_J_V_interface=string J_V_ifname=wgclient T_J_V_link_up=boolean LOGNAME=root DEVICENAME= T_J_V_action=int TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin CONFIG_LIST_STATE= J_V_interface=wgclient K_J_V= action ifname link_up address_external keep interface J_V_link_up=1 J_V_action=0 T_J_V_address_external=boolean N_J_V_link_up=link-up T_J_V_keep=boolean PWD=/ JSON_CUR=J_V CONFIG_SECTIONS=global AzireVPN Mullvad FromApp group_9529 group_2496 group_5462 group_714 peer_2001 CONFIG_cfg030f15_ports=
Sun Jun 30 12:20:13 2024 user.notice mwan3[13481]: Execute ifup event on interface wgclient (wgclient)
Sun Jun 30 12:20:13 2024 user.notice mwan3[13481]: Starting tracker on interface wgclient (wgclient)
Sun Jun 30 12:20:19 2024 user.notice firewall: Reloading firewall due to ifup of wgclient (wgclient)
Sun Jun 30 12:20:59 2024 daemon.notice netifd: Interface 'wgclient' has lost the connection
Sun Jun 30 12:21:00 2024 user.notice mwan3[14877]: Execute ifdown event on interface wgclient (unknown)
Sun Jun 30 12:21:06 2024 daemon.notice netifd: wgclient (15141): [!] Section @forwarding[0] is disabled, ignoring section
Sun Jun 30 12:21:06 2024 daemon.notice netifd: wgclient (15141): [!] Section @forwarding[1] is disabled, ignoring section
Sun Jun 30 12:21:06 2024 daemon.notice netifd: wgclient (15141): [!] Section nat6 option 'reload' is not supported by fw4
Sun Jun 30 12:21:06 2024 daemon.notice netifd: wgclient (15141): [!] Section gls2s option 'reload' is not supported by fw4
Sun Jun 30 12:21:06 2024 daemon.notice netifd: wgclient (15141): [!] Section gls2s specifies unreachable path '/var/etc/gls2s.include', ignoring section
Sun Jun 30 12:21:06 2024 daemon.notice netifd: wgclient (15141): [!] Section glblock option 'reload' is not supported by fw4
Sun Jun 30 12:21:06 2024 daemon.notice netifd: wgclient (15141): [!] Section vpn_server_policy option 'reload' is not supported by fw4
Sun Jun 30 12:21:06 2024 daemon.notice netifd: wgclient (15141): [!] Automatically including '/usr/share/nftables.d/chain-pre/mangle_output/01-process_mark.nft'
Sun Jun 30 12:21:06 2024 daemon.notice netifd: wgclient (15141): [!] Automatically including '/usr/share/nftables.d/chain-post/mangle_output/out_conn_mark_restore.nft'
Sun Jun 30 12:21:07 2024 daemon.notice netifd: Interface 'wgclient' is now down
Sun Jun 30 12:21:07 2024 daemon.notice netifd: Interface 'wgclient' is setting up now
Sun Jun 30 12:21:08 2024 daemon.notice netifd: wgclient (15419): sh: 1: unknown operand
Sun Jun 30 12:21:11 2024 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
VPN conf:
[Interface]
Address = 10.0.0.4/32
PrivateKey = <client-private-key>
DNS = 8.8.8.8
[Peer]
AllowedIPs = 0.0.0.0/0
Endpoint = <server-ip>:41194
PersistentKeepalive = 15
PublicKey = <server-pub-key>
