Whatever I do, I’m unable to use GL-MT300N as a VPN client, either for OpenVPN or WireGuard.
I have two VPNs: PiVPN and Mullvad.
My PiVPN’s .ovpn files fail when I import them, probably because they contain my log-in credentials. I have tried to create new ones without these credentials baked-in but so far I’ve had no luck.
I have tried to connect to Mullvad using the built-in WireGuard wizard on the router, but they aren’t accepted either.
If anyone has had any luck with either configuration, I’d appreciate a bit of help please.
Are they encoded .OVPN files, or not? There are usually differences with options for OpenVPN; you’ll need the unencoded version to update and debug most of the time- or login to the service via ssh to your router and try running openvpn ‘path-to-config’ for further debugging.
It does look like pivpn add nopass should have worked to create a user without a password.
Try using scp to copy your file to root@:/tmp and then login to it using ssh, then try running openvpn /tmp/ and check for errors. I’m afraid I’m not completely versed with the most recent build of GL’s wrapper; I’m much more familiar with v2.
I was probably making some rookie error (I’m obviously not very VPN-literate) so in the end I gave up. I realised that it would probably be better to use WireGuard than OpenVPN for my private VPN so I’ll probably buy another GL-MT300N for that purpose and set it up as a Wireguard Server. Thanks for your help anyway.
No, no errors; it showed that it was connected but it just didn’t connect. In the end I talked it through with Mullvad and they suggested that I simply open the configuration file in a text editor and paste it in. That worked, although I had to play about with the VPN policies as well.
