modem is alive! That is good news.
With mentioned configuration of modem:
config interface 'modem'
option proto 'ncm'
option device '/dev/cdc-wdm0'
option dialnum '*99#'
option apn 'darmowy'
option ifname 'wwan0'
router connects to the Internet, only while modem is connected to the routers USB port from the beginning of booting of the router.
It connects to the Internet automatically.
Even then are some problems.
I can ping addresses from router shell
root@GL-MT300N-V2:~# ping google.com
PING google.com (172.217.16.46): 56 data bytes
64 bytes from 172.217.16.46: seq=0 ttl=56 time=17.150 ms
64 bytes from 172.217.16.46: seq=1 ttl=56 time=35.051 ms
64 bytes from 172.217.16.46: seq=2 ttl=56 time=26.644 ms
But cannot form the client connected to the LAN:
user@host:~$ ping google.com
PING google.com (172.217.16.46) 56(84) bytes of data.
From console.gl-inet.com (192.168.8.1) icmp_seq=1 Destination Port Unreachable
From console.gl-inet.com (192.168.8.1) icmp_seq=2 Destination Port Unreachable
From console.gl-inet.com (192.168.8.1) icmp_seq=3 Destination Port Unreachable
There is still unresolved problem of the connecting modem after router boot-up.
if I connect modem to the USB port, after router boot-up, the connection to the Internet cannot be established.
Logread with modem connected to the USB port from the beginning of router booting procedure,
connection to Internet established:
kern.info kernel: [ 0.000000] Board has DDR2
kern.info kernel: [ 0.000000] Analog PMU set to hw control
kern.info kernel: [ 0.000000] Digital PMU set to hw control
kern.info kernel: [ 0.000000] SoC Type: MediaTek MT7628AN ver:1 eco:2
kern.info kernel: [ 0.000000] bootconsole [early0] enabled
kern.info kernel: [ 0.000000] CPU0 revision is: 00019655 (MIPS 24KEc)
kern.info kernel: [ 0.000000] MIPS: machine is GL-MT300N-V2
kern.info kernel: [ 0.000000] Determined physical RAM map:
kern.info kernel: [ 0.000000] memory: 08000000 @ 00000000 (usable)
kern.info kernel: [ 0.000000] Initrd not found or empty - disabling initrd
kern.info kernel: [ 0.000000] Zone ranges:
kern.info kernel: [ 0.000000] Normal [mem 0x0000000000000000-0x0000000007ffffff]
kern.info kernel: [ 0.000000] Movable zone start for each node
kern.info kernel: [ 0.000000] Early memory node ranges
kern.info kernel: [ 0.000000] node 0: [mem 0x0000000000000000-0x0000000007ffffff]
kern.info kernel: [ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000007ffffff]
kern.debug kernel: [ 0.000000] On node 0 totalpages: 32768
kern.debug kernel: [ 0.000000] free_area_init_node: node 0, pgdat 803bc4b0, node_mem_map 81000000
kern.debug kernel: [ 0.000000] Normal zone: 256 pages used for memmap
kern.debug kernel: [ 0.000000] Normal zone: 0 pages reserved
kern.debug kernel: [ 0.000000] Normal zone: 32768 pages, LIFO batch:7
kern.warn kernel: [ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
kern.warn kernel: [ 0.000000] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
kern.debug kernel: [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
kern.debug kernel: [ 0.000000] pcpu-alloc: [0] 0
kern.info kernel: [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
kern.notice kernel: [ 0.000000] Kernel command line: console=ttyS0,115200 rootfstype=squashfs,jffs2
kern.info kernel: [ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
kern.info kernel: [ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
kern.info kernel: [ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
kern.info kernel: [ 0.000000] Writing ErrCtl register=00000006
kern.info kernel: [ 0.000000] Readback ErrCtl register=00000006
kern.info kernel: [ 0.000000] Memory: 125552K/131072K available (3059K kernel code, 145K rwdata, 728K rodata, 156K init, 200K bss, 5520K reserved, 0K cma-reserved)
kern.info kernel: [ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
kern.info kernel: [ 0.000000] NR_IRQS:256
kern.info kernel: [ 0.000000] intc: using register map from devicetree
kern.info kernel: [ 0.000000] CPU Clock: 575MHz
kern.crit kernel: [ 0.000000] clocksource_probe: no matching clocksources found
kern.info kernel: [ 0.000000] clocksource: MIPS: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6647862422 ns
kern.info kernel: [ 0.000012] sched_clock: 32 bits at 287MHz, resolution 3ns, wraps every 7469508094ns
kern.info kernel: [ 0.007529] Calibrating delay loop... 380.92 BogoMIPS (lpj=1904640)
kern.info kernel: [ 0.069996] pid_max: default: 32768 minimum: 301
kern.info kernel: [ 0.074599] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
kern.info kernel: [ 0.080941] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
kern.info kernel: [ 0.094305] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
kern.info kernel: [ 0.103813] futex hash table entries: 256 (order: -1, 3072 bytes)
kern.info kernel: [ 0.109845] pinctrl core: initialized pinctrl subsystem
kern.info kernel: [ 0.116267] NET: Registered protocol family 16
kern.info kernel: [ 0.139923] mt7621_gpio 10000600.gpio: registering 32 gpios
kern.info kernel: [ 0.145494] mt7621_gpio 10000600.gpio: registering 32 gpios
kern.info kernel: [ 0.150926] mt7621_gpio 10000600.gpio: registering 32 gpios
kern.info kernel: [ 0.158170] clocksource: Switched to clocksource MIPS
kern.info kernel: [ 0.164524] NET: Registered protocol family 2
kern.info kernel: [ 0.169795] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
kern.info kernel: [ 0.176488] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
kern.info kernel: [ 0.182681] TCP: Hash tables configured (established 1024 bind 1024)
kern.info kernel: [ 0.188878] UDP hash table entries: 256 (order: 0, 4096 bytes)
kern.info kernel: [ 0.194478] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
kern.info kernel: [ 0.200864] NET: Registered protocol family 1
kern.debug kernel: [ 0.205088] PCI: CLS 0 bytes, default 32
kern.warn kernel: [ 0.210641] Crashlog allocated RAM at address 0x3f00000
kern.info kernel: [ 0.232883] squashfs: version 4.0 (2009/01/31) Phillip Lougher
kern.info kernel: [ 0.238544] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
kern.info kernel: [ 0.250805] io scheduler noop registered
kern.info kernel: [ 0.254543] io scheduler deadline registered (default)
kern.info kernel: [ 0.260376] gpio-export gpio_export: 1 gpio(s) exported
kern.info kernel: [ 0.265608] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
kern.info kernel: [ 0.275415] console [ttyS0] disabled
kern.info kernel: [ 0.278906] 10000c00.uartlite: ttyS0 at MMIO 0x10000c00 (irq = 28, base_baud = 2500000) is a 16550A
kern.info kernel: [ 0.287610] console [ttyS0] enabled
kern.info kernel: [ 0.294648] bootconsole [early0] disabled
kern.info kernel: [ 0.304467] spi-mt7621 10000b00.spi: sys_freq: 191666666
kern.info kernel: [ 0.315674] m25p80 spi32766.0: using chunked io (size=32)
kern.info kernel: [ 0.321239] m25p80 spi32766.0: w25q128 (16384 Kbytes)
kern.notice kernel: [ 0.326396] 4 ofpart partitions found on MTD device spi32766.0
kern.notice kernel: [ 0.332326] Creating 4 MTD partitions on "spi32766.0":
kern.notice kernel: [ 0.337544] 0x000000000000-0x000000030000 : "u-boot"
kern.notice kernel: [ 0.344434] 0x000000030000-0x000000040000 : "u-boot-env"
kern.notice kernel: [ 0.351821] 0x000000040000-0x000000050000 : "factory"
kern.notice kernel: [ 0.358835] 0x000000050000-0x000000f50000 : "firmware"
kern.notice kernel: [ 0.413988] 2 uimage-fw partitions found on MTD device firmware
kern.notice kernel: [ 0.420046] 0x000000050000-0x000000192d23 : "kernel"
kern.notice kernel: [ 0.426738] 0x000000192d23-0x000000f50000 : "rootfs"
kern.notice kernel: [ 0.433690] mtd: device 5 (rootfs) set to be root filesystem
kern.notice kernel: [ 0.439605] 1 squashfs-split partitions found on MTD device rootfs
kern.notice kernel: [ 0.445885] 0x000000980000-0x000000f50000 : "rootfs_data"
kern.info kernel: [ 0.462753] rt3050-esw 10110000.esw: link changed 0x00
kern.info kernel: [ 0.470448] mtk_soc_eth 10100000.ethernet eth0: mediatek frame engine at 0xb0100000, irq 5
kern.info kernel: [ 0.479600] mt7621_wdt 10000120.watchdog: Initialized
kern.info kernel: [ 0.486257] NET: Registered protocol family 10
kern.info kernel: [ 0.494573] NET: Registered protocol family 17
kern.info kernel: [ 0.499252] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
kern.info kernel: [ 0.512076] 8021q: 802.1Q VLAN Support v1.8
kern.info kernel: [ 0.518101] hctosys: unable to open rtc device (rtc0)
kern.info kernel: [ 0.531201] VFS: Mounted root (squashfs filesystem) readonly on device 31:5.
kern.info kernel: [ 0.539287] Freeing unused kernel memory: 156K
user.info kernel: [ 2.359390] init: Console is alive
user.info kernel: [ 2.363063] init: - watchdog -
user.info kernel: [ 6.299847] kmodloader: loading kernel modules from /etc/modules-boot.d/*
kern.info kernel: [ 6.388709] usbcore: registered new interface driver usbfs
kern.info kernel: [ 6.394405] usbcore: registered new interface driver hub
kern.info kernel: [ 6.399966] usbcore: registered new device driver usb
kern.info kernel: [ 6.411528] exFAT: Version 1.2.9
kern.notice kernel: [ 6.456003] SCSI subsystem initialized
kern.info kernel: [ 6.466875] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
kern.info kernel: [ 6.475435] ehci-platform: EHCI generic platform driver
kern.info kernel: [ 6.491063] phy phy-10120000.usbphy.0: remote usb device wakeup disabled
kern.info kernel: [ 6.497872] phy phy-10120000.usbphy.0: UTMI 16bit 30MHz
kern.info kernel: [ 6.503220] ehci-platform 101c0000.ehci: EHCI Host Controller
kern.info kernel: [ 6.509122] ehci-platform 101c0000.ehci: new USB bus registered, assigned bus number 1
kern.info kernel: [ 6.517274] ehci-platform 101c0000.ehci: irq 26, io mem 0x101c0000
kern.info kernel: [ 6.538192] ehci-platform 101c0000.ehci: USB 2.0 started, EHCI 1.00
kern.info kernel: [ 6.545695] hub 1-0:1.0: USB hub found
kern.info kernel: [ 6.549935] hub 1-0:1.0: 1 port detected
kern.info kernel: [ 6.557493] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
kern.info kernel: [ 6.565647] ohci-platform: OHCI generic platform driver
kern.info kernel: [ 6.571275] ohci-platform 101c1000.ohci: Generic Platform OHCI controller
kern.info kernel: [ 6.578240] ohci-platform 101c1000.ohci: new USB bus registered, assigned bus number 2
kern.info kernel: [ 6.586353] ohci-platform 101c1000.ohci: irq 26, io mem 0x101c1000
kern.info kernel: [ 6.653387] hub 2-0:1.0: USB hub found
kern.info kernel: [ 6.657608] hub 2-0:1.0: 1 port detected
kern.info kernel: [ 6.664614] uhci_hcd: USB Universal Host Controller Interface driver
kern.info kernel: [ 6.685217] sdhci: Secure Digital Host Controller Interface driver
kern.info kernel: [ 6.691564] sdhci: Copyright(c) Pierre Ossman
kern.info kernel: [ 6.697385] sdhci-pltfm: SDHCI platform and OF driver helper
kern.info kernel: [ 6.707799] usbcore: registered new interface driver usb-storage
user.info kernel: [ 6.717440] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
user.info kernel: [ 6.735271] init: - preinit -
kern.info kernel: [ 6.986438] usb 1-1: new high-speed USB device number 2 using ehci-platform
kern.notice kernel: [ 7.247314] random: procd: uninitialized urandom read (4 bytes read, 13 bits of entropy available)
kern.info kernel: [ 7.261192] usb-storage 1-1:1.0: USB Mass Storage device detected
kern.info kernel: [ 7.286190] scsi host0: usb-storage 1-1:1.0
kern.info kernel: [ 7.291516] usb-storage 1-1:1.1: USB Mass Storage device detected
kern.info kernel: [ 7.309186] scsi host1: usb-storage 1-1:1.1
kern.info kernel: [ 7.652544] rt3050-esw 10110000.esw: link changed 0x00
kern.notice kernel: [ 8.289252] scsi 0:0:0:0: CD-ROM HUAWEI Mass Storage 2.31 PQ: 0 ANSI: 2
kern.notice kernel: [ 8.309380] scsi 1:0:0:0: Direct-Access HUAWEI TF CARD Storage 2.31 PQ: 0 ANSI: 2
kern.notice kernel: [ 8.323800] sd 1:0:0:0: [sda] Attached SCSI removable disk
kern.notice kernel: [ 11.385600] jffs2: notice: (430) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
user.info kernel: [ 11.403527] mount_root: switching to jffs2 overlay
user.warn kernel: [ 11.427067] urandom-seed: Seeding with /etc/urandom.seed
user.info kernel: [ 11.554994] procd: - early -
user.info kernel: [ 11.558030] procd: - watchdog -
user.info kernel: [ 12.275373] procd: - watchdog -
user.info kernel: [ 12.278932] procd: - ubus -
kern.notice kernel: [ 12.833816] random: ubusd: uninitialized urandom read (4 bytes read, 24 bits of entropy available)
kern.notice kernel: [ 12.898469] random: ubusd: uninitialized urandom read (4 bytes read, 24 bits of entropy available)
kern.notice kernel: [ 12.916377] random: ubusd: uninitialized urandom read (4 bytes read, 24 bits of entropy available)
kern.notice kernel: [ 12.938350] random: ubusd: uninitialized urandom read (4 bytes read, 24 bits of entropy available)
kern.notice kernel: [ 12.972147] random: ubusd: uninitialized urandom read (4 bytes read, 24 bits of entropy available)
kern.notice kernel: [ 12.981392] random: ubusd: uninitialized urandom read (4 bytes read, 24 bits of entropy available)
kern.notice kernel: [ 13.003343] random: ubusd: uninitialized urandom read (4 bytes read, 24 bits of entropy available)
kern.notice kernel: [ 13.169212] random: ubusd: uninitialized urandom read (4 bytes read, 25 bits of entropy available)
user.info kernel: [ 13.179190] procd: - init -
kern.notice kernel: [ 13.571614] random: jshn: uninitialized urandom read (4 bytes read, 25 bits of entropy available)
user.info kernel: [ 14.116290] kmodloader: loading kernel modules from /etc/modules.d/*
kern.info kernel: [ 14.183485] ntfs: driver 2.1.32 [Flags: R/O MODULE].
kern.info kernel: [ 14.533001] tun: Universal TUN/TAP device driver, 1.6
kern.info kernel: [ 14.538138] tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
kern.info kernel: [ 14.577724] l2tp_core: L2TP core driver, V2.0
kern.info kernel: [ 14.592389] l2tp_netlink: L2TP netlink interface
kern.info kernel: [ 14.622513] gre: GRE over IPv4 demultiplexor driver
kern.info kernel: [ 14.721515] ip_gre: GRE over IPv4 tunneling driver
kern.info kernel: [ 14.773949] ip6_tables: (C) 2000-2006 Netfilter Core Team
kern.info kernel: [ 14.813327] Netfilter messages via NETLINK v0.30.
kern.info kernel: [ 14.835713] ip_set: protocol 6
kern.info kernel: [ 14.946218] i2c /dev entries driver
kern.info kernel: [ 15.001231] Linux video capture interface: v2.00
kern.info kernel: [ 15.119741] u32 classifier
kern.info kernel: [ 15.122498] input device check on
kern.info kernel: [ 15.126206] Actions configured
kern.info kernel: [ 15.162236] Mirror/redirect action on
kern.info kernel: [ 15.194562] nf_conntrack version 0.5.0 (1964 buckets, 7856 max)
kern.info kernel: [ 15.277898] usb 1-1: USB disconnect, device number 2
kern.info kernel: [ 15.307616] fuse init (API version 7.23)
kern.info kernel: [ 15.878285] usb 1-1: new high-speed USB device number 3 using ehci-platform
kern.info kernel: [ 16.173321] usb-storage 1-1:1.2: USB Mass Storage device detected
kern.info kernel: [ 16.190430] scsi host2: usb-storage 1-1:1.2
kern.info kernel: [ 16.195661] usb-storage 1-1:1.3: USB Mass Storage device detected
kern.info kernel: [ 16.388469] scsi host3: usb-storage 1-1:1.3
kern.warn kernel: [ 16.697537]
kern.warn kernel: [ 16.697537] === pAd = c06a0000, size = 1402624 ===
kern.warn kernel: [ 16.707176] <-- RTMPAllocTxRxRingMemory, Status=0, ErrorValue=0x
kern.warn kernel: [ 16.714512] <-- RTMPAllocAdapterBlock, Status=0
kern.warn kernel: [ 16.719146] RtmpChipOpsHook(748): Not support for HIF_MT yet!
kern.warn kernel: [ 16.724969] mt7628_init()-->
kern.warn kernel: [ 16.727896] mt7628_init(FW(8a00), HW(8a01), CHIPID(7628))
kern.warn kernel: [ 16.733385] e2.bin mt7628_init(1142)::(2), pChipCap->fw_len(63536)
kern.warn kernel: [ 16.739665] mt_bcn_buf_init(289): Not support for HIF_MT yet!
kern.warn kernel: [ 16.745488] <--mt7628_init()
kern.info kernel: [ 16.853062] usbcore: registered new interface driver cdc_acm
kern.info kernel: [ 16.858882] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
kern.info kernel: [ 16.892255] usbcore: registered new interface driver cdc_wdm
-01-31-0-ge882dff19e7f
kern.info kernel: [ 16.918069] Backport generated by backports.git backports-20160324-13-g24da7d3c
kern.info kernel: [ 16.977854] ip_tables: (C) 2000-2006 Netfilter Core Team
kern.info kernel: [ 17.002293] usbcore: registered new interface driver ipheth
kern.info kernel: [ 17.177971] usbcore: registered new interface driver usbserial
kern.info kernel: [ 17.184086] usbcore: registered new interface driver usbserial_generic
kern.info kernel: [ 17.190883] usbserial: USB Serial support registered for generic
kern.notice kernel: [ 17.200211] scsi 2:0:0:0: CD-ROM HUAWEI Mass Storage 2.31 PQ: 0 ANSI: 2
kern.info kernel: [ 17.359521] xt_time: kernel timezone is -0000
kern.info kernel: [ 17.369353] usbcore: registered new interface driver cdc_ether
kern.notice kernel: [ 17.390091] scsi 3:0:0:0: Direct-Access HUAWEI TF CARD Storage 2.31 PQ: 0 ANSI: 2
kern.notice kernel: [ 17.404129] sd 3:0:0:0: [sda] Attached SCSI removable disk
kern.info kernel: [ 17.414983] usbcore: registered new interface driver cdc_ncm
kern.info kernel: [ 17.519319] usbcore: registered new interface driver cp210x
kern.info kernel: [ 17.525093] usbserial: USB Serial support registered for cp210x
kern.info kernel: [ 17.565709] gspca_main: v2.14.0 registered
kern.info kernel: [ 17.581892] usbcore: registered new interface driver sonixb
kern.info kernel: [ 17.602741] usbcore: registered new interface driver sonixj
kern.info kernel: [ 17.627550] usbcore: registered new interface driver gspca_zc3xx
kern.info kernel: [ 17.669448] huawei_cdc_ncm 1-1:1.1: MAC-Address: xx:xx:xx:xx:xx:xx
kern.info kernel: [ 17.675755] huawei_cdc_ncm 1-1:1.1: setting rx_max = 16384
kern.info kernel: [ 17.698935] huawei_cdc_ncm 1-1:1.1: setting tx_max = 16384
kern.info kernel: [ 17.718253] huawei_cdc_ncm 1-1:1.1: NDP will be placed at end of frame for this device.
kern.info kernel: [ 17.726695] huawei_cdc_ncm 1-1:1.1: cdc-wdm0: USB WDM device
kern.info kernel: [ 17.733798] huawei_cdc_ncm 1-1:1.1 wwan0: register 'huawei_cdc_ncm' at usb-101c0000.ehci-1, Huawei CDC NCM device, xx:xx:xx:xx:xx:xx
kern.info kernel: [ 17.746149] usbcore: registered new interface driver huawei_cdc_ncm
kern.info kernel: [ 17.939939] PPP generic driver version 2.4.2
kern.info kernel: [ 17.959924] PPP MPPE Compression module registered
kern.info kernel: [ 17.979359] NET: Registered protocol family 24
kern.info kernel: [ 17.986088] PPTP driver version 0.8.5
kern.info kernel: [ 18.000024] usbcore: registered new interface driver qmi_wwan
kern.info kernel: [ 18.022786] usbcore: registered new interface driver rndis_host
kern.info kernel: [ 18.089425] usbcore: registered new interface driver sierra
kern.info kernel: [ 18.095232] usbserial: USB Serial support registered for Sierra USB modem
kern.info kernel: [ 18.130463] usbcore: registered new interface driver sierra_net
kern.info kernel: [ 18.170990] usbcore: registered new interface driver uvcvideo
kern.info kernel: [ 18.176828] USB Video Class driver (1.1.1)
kern.info kernel: [ 18.214585] l2tp_ppp: PPPoL2TP kernel driver, V2.0
kern.info kernel: [ 18.227355] usbcore: registered new interface driver option
kern.info kernel: [ 18.233234] usbserial: USB Serial support registered for GSM modem (1-port)
kern.info kernel: [ 18.240800] option 1-1:1.0: GSM modem (1-port) converter detected
kern.info kernel: [ 18.247318] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB0
kern.info kernel: [ 18.331488] usbcore: registered new interface driver rt2800usb
user.info kernel: [ 18.346042] kmodloader: done loading kernel modules from /etc/modules.d/*
daemon.notice procd: /etc/rc.d/S19initswitch: uci: Entry not found
user.notice : Added device handler type: 8021ad
user.notice : Added device handler type: 8021q
user.notice : Added device handler type: macvlan
user.notice : Added device handler type: bridge
user.notice : Added device handler type: Network device
user.notice : Added device handler type: tunnel
kern.warn kernel: [ 25.641855] TX_BCN DESC a696e000 size = 320
kern.warn kernel: [ 25.646176] RX[0] DESC a6978000 size = 2048
kern.warn kernel: [ 25.653490] RX[1] DESC a6979000 size = 1024
authpriv.info dropbear[1201]: Not backgrounding
kern.warn kernel: [ 25.715401] prepare to get e2p access------------
kern.warn kernel: [ 25.720515] E2pAccessMode=2
kern.warn kernel: [ 25.724098] cfg_mode=9
kern.warn kernel: [ 25.726487] cfg_mode=9
kern.warn kernel: [ 25.728913] wmode_band_equal(): Band Equal!
kern.warn kernel: [ 25.737336] APSDCapable[0]=1
kern.warn kernel: [ 25.740280] APSDCapable[1]=1
kern.warn kernel: [ 25.743198] APSDCapable[2]=1
kern.warn kernel: [ 25.746119] APSDCapable[3]=1
kern.warn kernel: [ 25.749060] APSDCapable[4]=1
kern.warn kernel: [ 25.751979] APSDCapable[5]=1
kern.warn kernel: [ 25.754895] APSDCapable[6]=1
kern.warn kernel: [ 25.757811] APSDCapable[7]=1
kern.warn kernel: [ 25.760745] APSDCapable[8]=1
kern.warn kernel: [ 25.763663] APSDCapable[9]=1
kern.warn kernel: [ 25.766579] APSDCapable[10]=1
kern.warn kernel: [ 25.769600] APSDCapable[11]=1
kern.warn kernel: [ 25.772605] APSDCapable[12]=1
kern.warn kernel: [ 25.775610] APSDCapable[13]=1
kern.warn kernel: [ 25.778635] APSDCapable[14]=1
kern.warn kernel: [ 25.781643] APSDCapable[15]=1
kern.warn kernel: [ 25.784650] default ApCliAPSDCapable[0]=1
kern.warn kernel: [ 25.984121] Key1Str is Invalid key length(0) or Type(0)
kern.warn kernel: [ 25.989805] Key2Str is Invalid key length(0) or Type(0)
kern.warn kernel: [ 25.995472] Key3Str is Invalid key length(0) or Type(0)
kern.warn kernel: [ 26.001162] Key4Str is Invalid key length(0) or Type(0)
kern.warn kernel: [ 26.065108] RTMPSetDefaultChannel() : default channel to 1
kern.warn kernel: [ 26.070841] load fw image from fw_header_image
kern.warn kernel: [ 26.075350] AndesMTLoadFwMethod1(2548)::pChipCap->fw_len(63536)
daemon.notice procd: /etc/rc.d/S50mjpg-streamer: /etc/rc.d/S50mjpg-streamer: device '/dev/video0' does not exist
user.notice root: drv_ralink_cleanup
daemon.notice procd: /etc/init.d/network: Command failed: Not found
daemon.notice netifd: Interface 'lan' is enabled
daemon.notice netifd: Interface 'lan' is setting up now
daemon.notice netifd: Interface 'lan' is now up
daemon.notice netifd: Interface 'loopback' is enabled
daemon.notice netifd: Interface 'loopback' is setting up now
daemon.notice netifd: Interface 'loopback' is now up
daemon.notice netifd: Interface 'modem' is setting up now
daemon.notice netifd: Interface 'wan' is enabled
daemon.notice netifd: Interface 'wan6' is enabled
daemon.info odhcpd[1154]: Raising SIGUSR1 due to address change on br-lan
daemon.notice netifd: bridge 'br-lan' link is up
daemon.notice netifd: Interface 'lan' has link connectivity
daemon.notice netifd: Network device 'eth0' link is up
daemon.notice netifd: VLAN 'eth0.1' link is up
daemon.notice netifd: Network device 'lo' link is up
daemon.notice netifd: Interface 'loopback' has link connectivity
daemon.notice netifd: VLAN 'eth0.2' link is up
daemon.notice netifd: Interface 'wan' has link connectivity
daemon.notice netifd: Interface 'wan' is setting up now
daemon.notice netifd: Interface 'wan6' has link connectivity
daemon.notice netifd: Interface 'wan6' is setting up now
daemon.notice netifd: wan (1526): udhcpc: started, v1.25.1
daemon.info odhcpd[1154]: Using a RA lifetime of 0 seconds on br-lan
daemon.notice odhcpd[1154]: Failed to send to ff02::1%br-lan (Address not available)
daemon.notice netifd: wan (1526): udhcpc: sending discover
daemon.err odhcp6c[1525]: Failed to send DHCPV6 message to ff02::1:2 (Address not available)
daemon.err insmod: module is already loaded - xt_multiport
daemon.err insmod: module is already loaded - xt_connmark
daemon.err insmod: module is already loaded - xt_comment
daemon.err insmod: module is already loaded - xt_length
user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
daemon.notice netifd: modem (1450): sending -> AT
daemon.notice netifd: modem (1450): sending -> ATZ
daemon.notice netifd: modem (1450): sending -> ATQ0
daemon.notice netifd: modem (1450): sending -> ATV1
daemon.notice netifd: modem (1450): sending -> ATE1
daemon.notice netifd: modem (1450): sending -> ATS0=0
daemon.info dnsmasq[2179]: started, version 2.78 cachesize 150
daemon.info dnsmasq[2179]: DNS service limited to local subnets
daemon.info dnsmasq[2179]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-DNSSEC no-ID loop-detect inotify
daemon.info dnsmasq-dhcp[2179]: DHCP, IP range 192.168.8.100 -- 192.168.8.249, lease time 12h
daemon.info dnsmasq[2179]: using local addresses only for domain test
daemon.info dnsmasq[2179]: using local addresses only for domain onion
daemon.info dnsmasq[2179]: using local addresses only for domain localhost
daemon.info dnsmasq[2179]: using local addresses only for domain invalid
daemon.info dnsmasq[2179]: using local addresses only for domain example.net
daemon.info dnsmasq[2179]: using local addresses only for domain example.org
daemon.info dnsmasq[2179]: using local addresses only for domain example.com
daemon.info dnsmasq[2179]: using 3 more local addresses
daemon.warn dnsmasq[2179]: no servers found in /tmp/resolv.conf.auto, will retry
daemon.info dnsmasq[2179]: read /etc/hosts - 4 addresses
daemon.info dnsmasq[2179]: read /tmp/hosts/odhcpd - 0 addresses
daemon.info dnsmasq[2179]: read /tmp/hosts/dhcp.cfg02411c - 3 addresses
daemon.info dnsmasq-dhcp[2179]: read /etc/ethers - 0 addresses
daemon.crit xl2tpd[2208]: setsockopt recvref[30]: Protocol not available
daemon.info xl2tpd[2208]: Using l2tp kernel support.
daemon.info xl2tpd[2208]: xl2tpd version xl2tpd-1.3.6 started on GL-MT300N-V2 PID:2208
daemon.info xl2tpd[2208]: Written by Mark Spencer, Copyright (C) 1998, Adtran, Inc.
daemon.info xl2tpd[2208]: Forked by Scott Balmos and David Stipp, (C) 2001
daemon.info xl2tpd[2208]: Inherited by Jeff McAdams, (C) 2002
daemon.info xl2tpd[2208]: Forked again by Xelerance (www.xelerance.com) (C) 2006
daemon.info xl2tpd[2208]: Listening on IP address 0.0.0.0, port 1701
daemon.notice netifd: modem (1450): sending -> AT+CGDCONT=1,"IP","darmowy"
daemon.notice procd: /etc/rc.d/S96led: setting up led wifi
daemon.notice netifd: modem (1450): Starting network modem
daemon.notice netifd: modem (1450): sending -> AT^NDISDUP=1,1,"darmowy"
daemon.notice netifd: modem (1450): Setting up wwan0
daemon.notice netifd: Interface 'modem' is now up
daemon.notice netifd: Network device 'wwan0' link is up
daemon.notice netifd: Network alias 'wwan0' link is up
daemon.notice netifd: Interface 'modem_4' is enabled
daemon.notice netifd: Interface 'modem_4' has link connectivity
daemon.notice netifd: Interface 'modem_4' is setting up now
daemon.notice netifd: modem (1450): Command failed: Unknown error
daemon.notice netifd: modem_4 (2442): udhcpc: started, v1.25.1
daemon.notice netifd: modem_4 (2442): udhcpc: sending discover
daemon.notice netifd: modem_4 (2442): udhcpc: sending select for 100.82.168.2
daemon.notice netifd: modem_4 (2442): udhcpc: lease of 100.82.168.2 obtained, lease time 518400
daemon.notice netifd: Interface 'modem_4' is now up
daemon.info dnsmasq[2179]: reading /tmp/resolv.conf.auto
daemon.info dnsmasq[2179]: using nameserver 212.2.127.254#53
daemon.info dnsmasq[2179]: using nameserver 212.2.96.52#53
user.notice mwan3: ifup interface modem (wwan0)
daemon.notice procd: /etc/rc.d/S99ss-server:
daemon.info procd: - init complete -
daemon.notice odhcpd[1154]: Got DHCPv6 request
daemon.warn odhcpd[1154]: DHCPV6 CONFIRM IA_NA from 00040d417f137d79594245c2e9116f31db2b on br-lan: not on-link
daemon.info dnsmasq-dhcp[2179]: DHCPDISCOVER(br-lan) 192.168.8.116 xx:xx:xx:xx:xx:xx
daemon.info dnsmasq-dhcp[2179]: DHCPOFFER(br-lan) 192.168.8.116 xx:xx:xx:xx:xx:xx
daemon.info dnsmasq-dhcp[2179]: DHCPREQUEST(br-lan) 192.168.8.116 xx:xx:xx:xx:xx:xx
daemon.info dnsmasq-dhcp[2179]: DHCPACK(br-lan) 192.168.8.116 xx:xx:xx:xx:xx:xx xxx
Summing up:
- what to do to connect to the Internet with booted up router and then connected modem to the USB port ?
- what to do to allow LAN client to reach Internet ?
