GL-MT6000 (4.6.6-op24) - Docker Filesystem Problem
Using Version: 4.6.6-op24
After updating from 4.5.6, I am getting an issue with the docker not letting me install any image. The error message is
failed to register layer: lsetxattr security.capability /usr/lib/aarch64-linux-gnu/gstreamer1.0/gstreamer-1.0/gst-ptp-helper: operation not supported
I have reinstalled the docker module and changed the filesystems (ext4, f2fs, xfs) of the docker location, but I have had no luck.
It seems related to the CONFIG_KERNEL_EXT4_FS_SECURITY option when the GL-iNet team builds OpenWrt. Has anyone experienced this issue? If you fixed it, how did you resolve it?
You don't have any better option for running docker than your router? Just a rhetorical question I suppose.
