Firmware: 4.5.6
I recently set the 5Ghz (DFS) network to 160Mhz bandwidth and I noticed my Flint2 is disconnecting some devices by inactivity and I need to connect it manually to have it back to the network.
Usually it goes on this loop, until it become offline:
Fri Jan 26 05:23:07 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 05:23:07 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 05:23:10 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 05:23:10 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 05:23:13 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 05:23:13 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 05:23:40 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 05:23:40 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 05:23:56 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 05:23:56 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 05:24:00 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 05:24:00 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 05:24:03 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 05:24:03 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 05:24:06 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 05:24:06 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 05:24:09 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 05:24:09 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 05:32:26 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 05:32:26 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 05:32:29 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 05:32:29 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 05:32:32 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 05:32:32 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 05:35:28 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 05:35:28 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 05:38:18 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 05:38:18 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 05:38:21 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 05:38:21 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 05:38:25 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 05:38:25 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 05:38:28 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 05:38:28 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 05:38:31 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 05:38:31 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 05:38:47 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 05:38:47 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 05:38:50 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 05:38:50 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 05:40:25 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 05:40:25 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 05:40:28 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 05:40:28 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 05:40:31 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 05:40:31 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 05:40:34 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 05:40:34 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 05:40:37 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 05:40:37 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 05:40:41 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 05:40:41 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 05:40:44 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 05:40:44 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 05:46:07 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 05:46:07 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 05:46:10 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 05:46:10 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 05:46:28 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 05:46:28 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 05:46:31 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 05:46:31 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 05:46:49 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 05:46:49 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 05:46:52 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 05:46:52 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 06:00:01 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 06:00:01 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 06:00:39 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 06:00:39 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 06:00:42 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 06:00:42 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 06:00:58 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 06:00:58 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 06:01:02 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 06:01:02 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 06:01:19 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 06:01:19 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 06:03:15 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 06:03:15 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 06:03:32 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 06:03:32 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 06:03:35 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 06:03:35 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 06:03:52 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 06:03:52 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 06:03:55 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 06:03:55 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 06:04:29 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 06:04:29 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 06:04:32 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 06:04:32 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 06:04:35 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 06:04:35 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 06:05:02 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 06:05:02 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 06:05:05 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 06:05:05 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 06:05:08 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 06:05:08 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 06:05:29 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 06:05:29 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 06:08:10 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 06:08:10 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 06:08:13 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 06:08:13 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 06:08:16 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 06:08:16 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 06:08:20 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 06:08:20 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 06:08:23 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 06:08:23 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
Fri Jan 26 06:09:26 2024 daemon.notice hostapd: wlan1: AP-STA-DISCONNECTED 46:3a:f6:b1:01:8f:e9
Fri Jan 26 06:09:26 2024 daemon.info hostapd: wlan1: STA 46:3a:f6:b1:01:8f:e9 IEEE 802.11: disassociated
Fri Jan 26 06:09:27 2024 daemon.info hostapd: wlan1: STA 46:3a:f6:b1:01:8f:e9 IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
- Then, I connect it back to the network manually:
Fri Jan 26 07:41:43 2024 daemon.info hostapd: wlan1: STA 46:3a:f6:b1:01:8f:e9 IEEE 802.11: authenticated
Fri Jan 26 07:41:43 2024 daemon.info hostapd: wlan1: STA 46:3a:f6:b1:01:8f:e9 IEEE 802.11: associated (aid 1)
Fri Jan 26 07:41:43 2024 daemon.notice hostapd: wlan1: AP-STA-CONNECTED 46:3a:f6:b1:01:8f:e9 auth_alg=open
Fri Jan 26 07:41:43 2024 daemon.info hostapd: wlan1: STA 46:3a:f6:b1:01:8f:e9 RADIUS: starting accounting session 33946F47F2604F40
Fri Jan 26 07:41:43 2024 daemon.info hostapd: wlan1: STA 46:3a:f6:b1:01:8f:e9 WPA: pairwise key handshake completed (RSN)
Fri Jan 26 07:41:43 2024 daemon.notice hostapd: wlan1: EAPOL-4WAY-HS-COMPLETED 46:3a:f6:b1:01:8f:e9
Fri Jan 26 07:41:43 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9
Fri Jan 26 07:41:43 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.6.171 46:3a:f6:b1:01:8f:e9 Pixel-7
